the LED flash is too white(either in camera or video mode)
is there a way to make the color warmer?
thanks!
thanks!
That is an interesting question. I would guess that if the code is open for a developer to create an application to modify the LED power levels to increase and decrease intensities then you have a possible solution. Problem is I'm not sure if this would fall under Android's end or Samsung and possible proprietary files to control camera hardware & software. Then next question is this something that could be done on a stock device or would rooting be required to modify this if possible?
Awesome. Please do come back and share your experiences/outcome with everyone.
Good luck.
Just a thought:
What about a small piece of yellow Saran Wrap? or the cheap translucent file folders? (lots of different colors and available at any office store)
Just stick a piece over your flash, or if you are using a case just insert it between your phone and the case.
Good Luck
