1. herbmmm's Avatar
    I'm having a devil of a time adjusting the sound on my phone. I've tried sound in settings and have downloaded a couple of sound apps but nothing seems to help. My alarm is particularly loud! Anyone have any suggestions?
    04-18-2013 04:13 PM
  2. kris.richards's Avatar
    Your sound is too loud or too soft?
    04-18-2013 05:31 PM
  3. herbmmm's Avatar
    Its to loud! But I can't seem to adjust sound level eather way! Has anyone found an app that works well on the Note? I've tried several but none solved my problem.
    04-19-2013 07:54 AM
  4. Bobman's Avatar
    You can't adjust it? If you push one of the volume keys and then press the gear icon on the volume meter that shows up, what are the 4 different levels set at?
    I've never used a 3rd party volume app, so can't speak to that part of your question.
    04-19-2013 08:03 AM
  5. dpham00's Avatar
    If it is the alarm volume and you are using the stock app, just tap on the "MORE" button and it should allow you to change the volume for the alarm.
    If you have an issue with other volume settings, go to Settings > Sound > Volume
    Sent from my Verizon Samsung Galaxy Note II
    Attached Thumbnails Sound on Note ll-uploadfromtaptalk1366378501352.jpg   Sound on Note ll-uploadfromtaptalk1366378515415.jpg
    04-19-2013 08:38 AM
  6. dpham00's Avatar
    More button is at the bottom of the page
    04-19-2013 08:40 AM
  7. herbmmm's Avatar
    Just found the more button and it works!!!!
    04-19-2013 09:38 AM
  1. Putting books on my Kindle on the Note ll?
    By ShelaghDB in forum Samsung Galaxy Note 2
    Last Post: 09-28-2014, 06:57 PM
  2. How to know if a video will display & sound on a Note II
    By Landyman130 in forum Samsung Galaxy Note 2
    Last Post: 01-21-2013, 04:30 PM
  3. Why no sound plays to confirm e-mail has been SENT on Note 2??
    By billorg in forum Samsung Galaxy Note 2
    Last Post: 12-30-2012, 01:52 AM
  4. Turning off shutter sound on Droid
    By mugenprincess in forum General Help and How To
    Last Post: 08-31-2010, 02:26 AM
  5. notification sounds on Droid
    By steveandtracy7#AC in forum Motorola Droid
    Last Post: 01-19-2010, 06:00 PM
