1. aneftp's Avatar
    I don't know what the issue is. I have both Verizon and ATT service. With my Verizon sim, I can make and receive phone calls etc. No issues.
    But when I put my ATT sim into the Verizon Note 2, I can text and receive texts (although sometimes there is up to a 10 min delay). I can make outgoing phone calls.
    However, I am unable to receive incoming phone calls. Has anyone had any issues with using the Verizon Note 2 on GSM carriers. I know MMS won't work until you root it and change the APN.
    But I have a basic problem of not being able to have an incoming phone call ring at all. I rings 4 times and than goes to voicemail. I tried this on other ATT sims also and unable to receive incoming phone calls.
    Any suggestions.
    04-22-2013 08:01 AM
  2. aneftp's Avatar
    I solved my own question.
    Very strange. Apparently since I have a data block on my ATT lines. The Verizon Galaxy Note 2 does funky things and won't accept incoming phone calls with the ATT sim in.
    I removed the data block from the ATT sim line. And now the Verizon Galaxy Note 2 is able to receive incoming phone calls. Of course since I know have pay per use instead of a data block. I manually went and disabled the actual mobile data on the Note 2.
    Verizon doesn't make things simple.
    I don't care for data on my Note 2 on ATT since I carry 2 phones with me.
    But problem solved. Just weird the phone won't accept incoming phone calls with a data block on the ATT sim line.
    fankyousomuch likes this.
    04-22-2013 10:15 AM
  1. Anyone here using the Note 2 on Rogers in Canada?
    By eosman2k1 in forum Samsung Galaxy Note 2
    Last Post: 12-11-2012, 10:36 AM
  2. Which U.S. carrier are you using your Note 2 on?
    By Sh3ngLong in forum Samsung Galaxy Note 2
    Last Post: 12-07-2012, 08:56 AM
  3. Tmobile note 2 on att network?
    By sqa4life in forum AT&T Galaxy Note 2
    Last Post: 12-05-2012, 03:07 PM
  4. Nexus S NOT unlockable on att
    By wpbfjr in forum AT&T Nexus S
    Last Post: 05-04-2012, 11:29 AM
  5. Use Verizon DROID X on Alltel
    By schwars1 in forum Verizon
    Last Post: 01-05-2012, 07:31 PM
