1. signaltwins's Avatar
    I'm a little confused about the GPS and airplane mode on my Note 2.
    When the phone is in airplane mode, the GPS can't get a signal lock. According to GPS Test app, the phone sees zero satellites.
    However, if I turn on airplane mode when there is no SIM card in the phone, the GPS gets a signal lock within 3 to 5 seconds.
    I also tried this recently on a Trans-Atlantic flight. Halfway into the flight, I turned on my phone which was still in airplane mode, so no GPS lock at all. I turned airplane mode off and the GPS locked within 15 seconds. I was in a window seat with the phone pressed against the window. It managed to see 11 satellites. It was able to show me speed(MPH) and heading(degrees).
    Is this normal?
    04-24-2013 10:39 AM
  2. Shill1986's Avatar
    I would imagine that it disables the gps... Airplane usually does disable wifi, gps, and cell network... I hardly use it and never on the note 2
    Sent from my VZW Galaxy Note II, hyper powered via MeanBean 1.11
    - Hyperion 6,200MAh Extended Battery
    - Modded Otterbox to fit battery
    - An S-Pen (deal with it)
    04-24-2013 10:44 PM
  3. FlyingBackwards's Avatar
    I get a GPS signal just fine even when airplane mode is on.(with wifi off as well)
    Google Maps and GPS Test app can pick up the GPS satellites and get a lock within a couple of seconds, like usual.
    06-19-2013 09:54 PM
  1. GPS while in airplane mode?
    By skiddingus in forum Verizon Fascinate
    Last Post: 12-31-2015, 10:09 AM
  2. Can't receive text messages with same content more than once
    By beyondfrustrated in forum Droid RAZR MAXX
    Last Post: 01-21-2013, 11:31 PM
  3. Can anyone get GPS to lock in airplane mode (ie no cell signal)?
    By sfhub in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 11-10-2011, 08:04 AM
  4. no gps lock with rooted .605?
    By fi150l in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 09-30-2011, 02:21 PM
  5. Receiving Texts and Notifications while in Sleep Mode
    By drewbagel in forum Verizon HTC Thunderbolt
    Last Post: 04-25-2011, 11:31 AM
