1. fluidj's Avatar
    It doesn't appear that the VZW version of this phone has that option. Is there a way to get it without rooting?
    04-25-2013 06:27 AM
  2. pool_shark's Avatar
    Sure it does. Take a screen shot and write on that.
    sicario666 likes this.
    04-25-2013 07:03 AM
  3. fluidj's Avatar
    Are you being serious or trolling?
    I'm not talking about screen shots...i'm talking about photos taken with the camera.
    04-25-2013 07:15 AM
  4. pool_shark's Avatar
    Open the photo. Use the s-pen to take a screenshot. There is nothing else on the screen other than the photo, so the screenshot is of the photo.
    Then use the s-pen to write on it.
    Attached Thumbnails How do you write a note on the FRONT of a photo?-2013-04-25-08-25-51.jpg
    04-25-2013 07:24 AM
  5. PittiesRule's Avatar
    You could download Samsung photo editor from the Samsung app store.
    Sent thru cyberspace by my Samsung Galaxy Note 2
    04-25-2013 08:02 AM
  6. ejb1013's Avatar
    Yes its possible without rooting. There was an .APK floating around the XDA forums a while back and it just so happens that I still have it in my dropbox. Put this on your SD card and allow installs from unknown sources. Install it then open a picture, go to the menu and it will be an option under "advanced edit". This isn't something I created. I'm just passing it along. I've given you all the info I have and it worked for me with no issues at all and I'd assume the same for you ... if it doesn't, I wouldn't know what to tell you so whatever risk your taking (however small it may be) is on you.
    BTW .. yes the file name is in another language (looks like French?) dont worry about that. It was that way when I downloaded it.
    Photo Editor APK
    Enjoy
    04-25-2013 08:33 AM
  7. One_Angry_Panda's Avatar
    So do you just save it anywhere to the SD card?
    Photo Editor APK
    Enjoy
    04-25-2013 09:59 AM
  8. ejb1013's Avatar
    Yes. I usually just put mine on the root.
    04-25-2013 10:10 AM
  9. One_Angry_Panda's Avatar
    Thanks!
    ejb1013 likes this.
    04-25-2013 02:22 PM
  10. lpt2569's Avatar
    Sent from my SCH-I605
    Attached Thumbnails How do you write a note on the FRONT of a photo?-uploadfromtaptalk1366921468599.jpg
    ejb1013 likes this.
    04-25-2013 03:24 PM
  11. ejb1013's Avatar
    Glad I could help!
    Sent from my SCH-I605 using Tapatalk 2
    04-25-2013 03:55 PM
  12. lpt2569's Avatar
    Glad I could help!
    I've been using the screen shot method, but this is definitely nice to have. I've seen this apk floating around but never bothered until now. Thanks again.
    Sent from my GT-N8013 using Tapatalk 2
    ejb1013 likes this.
    04-25-2013 05:22 PM
  13. CallerHoller's Avatar
    Skitch on Google Play let's you write on stuff.
    https://play.google.com/store/apps/d...vernote.skitch
    wangster likes this.
    05-01-2013 09:56 PM
  1. How do you delete one event on the calendar in a recurring series
    By PWG09 in forum General Help and How To
    Last Post: 11-22-2017, 11:46 AM
  2. Replies: 61
    Last Post: 05-24-2014, 01:09 PM
  3. Replies: 1
    Last Post: 11-30-2011, 11:32 PM
  4. How do you turn off 3g on the x????
    By kroman1107 in forum Motorola Droid X
    Last Post: 01-05-2011, 11:50 AM
  5. How Do You Remove Unwanted Applications On The Evo?
    By TechieBrad in forum HTC EVO 4G
    Last Post: 10-17-2010, 02:39 AM
