1. herbmmm's Avatar
    I bought my Note two weeks ago and was immediately able to connect to a second Wi-Fi Router I put in the other end of our home where I usually us the phone(Computer at opposite end of house). For two weeks absolutely no connection problems! This morning I'm not able to connect to the extra router. No problem connecting to router next to computer. Anybody have any ideas why this is happening. The signal strength from the second router is very strong but phone says unable to Authenticate! Password is definitely correct!
    05-01-2013 03:01 PM
  2. sergeantandroid's Avatar
    Forget the wi-fi access point and then re-add it.
    - - - Updated - - -
    05-01-2013 03:05 PM
  3. zeuswsu's Avatar
    If your able to connect to the first router then it sounds like something got messed up on the second router that you are using as an access point. Have you tried unplugging then re-plugging in the routers?
    Sent from my SCH-I605 using Tapatalk 2
    05-01-2013 03:07 PM
  4. herbmmm's Avatar
    Tried both suggestions but no luck. Just read that if I open Wi-Fi page and click on menu and go to advanced and make sure "keep wi-fi on during sleep" is checked then go back ti Wi-Fi page and try reconnecting this should solve problem! It did!!!!!
    05-01-2013 03:15 PM
  1. Strange problem de-bloating after DL09
    By denzillion in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 01-16-2011, 02:38 PM
  2. Strange problem while trying to update. NEED HELP!
    By nismo300zx96 in forum Verizon Droid Incredible
    Last Post: 09-07-2010, 11:33 AM
  3. Help with Vonage and EVO - Strange Problem
    By jgladstone in forum HTC EVO 4G
    Last Post: 09-03-2010, 12:44 PM
  4. Strange problem with Google contacts
    By breugel in forum Verizon Droid Incredible
    Last Post: 08-21-2010, 10:38 PM
  5. Strange Problem
    By rtlsnke in forum HTC EVO 4G
    Last Post: 06-08-2010, 01:25 PM
