Thanks! I've had my N2 for 5-6 days now and was wondering why that tab was appearing and disappearing seemingly at will. Or what I was doing to make it do that.Long press the back button. It is the multi view tab.
You can also swipe down from the top to turn multi window on or off
Sent from my Galaxy Note 2 using Android Central Forums
BTW guys, you can also move the tab to other locations of the screen by long pressing on the tab when it's down and drag and drop it to another edge of the screen, and you can adjust the location of the tab on the edge to a lower or upper (left or right on the top edge) section in the same way.
Funny how the multi-window is one major feature for the GN2, yet most people don't seem to use it. I don't use it either, and I'm quite comfortable toggling between applications and windows the old fashioned way. habits die hard I suppose
This pretty much proves that Multiwindow is basically another Samsung gimmick. (At least for most people)
Surprised to see this many people with the same problem. Glad its solved
Sent from my SCH-I605 using AC Forums mobile app
