1. wangster's Avatar
    So... I finally ordered my Galaxy Note 2 through Costco. Debated for a long time between the S4 and Note 2 but I missed my beloved stylus from the Treo days. I'm planning to buy a 32 GB MicroSD card and I'm wondering if the class actually makes any difference.
    Has anybody tried both a class 6 and class 10 on the note 2? Can you tell the difference? I have a 16 GB class 6 laying around somewhere so I'm debating whether I should just use it or buy a class 10.
    05-07-2013 09:44 PM
  2. gaslucas39's Avatar
    of course class 10 is best. but most of time you can not sense the different between them.
    05-07-2013 11:16 PM
  3. signaltwins's Avatar
    Instead of the 32GB card.... I urge you to buy the Sandisk 64GB MicroSDXC card.
    It's around $50. You will not regret having the extra capacity.
    ($50 right now... I bought it when it was on sale for $39)
    Amazon.com: SanDisk Ultra 64 GB MicroSDXC Class 10 UHS-1 Memory Card with Adapter (SDSDQU-064G-AFFP-A)
    PossumPete likes this.
    05-07-2013 11:20 PM
  4. chuckh0308's Avatar
    If 16 GB is enough for you, I wouldn't spend money on a 32. You won't notice a difference between the Class 6 and the Class 10. But, if you need more space then you might as well get the Class 10 and I would personally go big and get the 64 GB card.
    05-07-2013 11:46 PM
  5. wangster's Avatar
    Thanks everyone. Looks like I'll see if the existing MicroSD will do the trick and just upgrade later down the road.
    05-08-2013 06:34 PM
  6. Robert Landry's Avatar
    Yep! No difference: Neither one or the other will be reliable on a Galaxie tab 2 10.1 !
    After a while, each card i tried became unseen by the tab. Like many of us, this might be poor components in the slot (reader) on this machine. I'm taking it back today. M
    07-12-2013 01:18 PM
  7. universeand's Avatar
    Good frugal move. Just transfer data later if required.
    07-12-2013 01:52 PM
  8. mskathy49's Avatar
    You mention that your galaxy note 2 ruined sd cards. Mine has done the same thing with a 32 and a 64 gb card. I lost years of information on the 32 gb card because I hadnt backed it up . The 64 gb card was a brand new samsung and it was ruined within 2 days. The phone doesn't see it neither does the computer. Did you find out a reason for that? I just set up a warranty replacement but if there are others doing this it sounds like there is no point.
    01-14-2014 05:14 PM
  1. Second SD card for Galaxy Note II
    By jlko in forum Verizon Galaxy Note 2
    Last Post: 12-07-2012, 08:15 PM
  2. CWM recovery for Galaxy Note
    By mxmarcus in forum Samsung Galaxy Note
    Last Post: 10-31-2011, 10:36 AM
  3. [Breaking news] Release date and price CONFIRMED for Galaxy Note!
    By NZtechfreak in forum General News & Discussion
    Last Post: 10-23-2011, 11:02 PM
  4. Explanation of microSD card classes and speeds
    By dcreed in forum Barnes & Noble Nook Color
    Last Post: 04-11-2011, 05:06 AM
  5. Replies: 11
    Last Post: 03-02-2011, 04:21 PM
