1. elvisgp's Avatar
    My battery life seems to be cut down by a few hours. Usually I will be at 50% after 15 hours. Now I'm at 50% after only 12 hours! My android os and system seem to be unusually high. Anybody else have the same problem/ a fix for this?
    Posted from the AC app
    05-09-2013 07:53 PM
  2. HarlyFan's Avatar
    http://img.tapatalk.com/d/13/05/10/7yba8enu.jpg
    http://img.tapatalk.com/d/13/05/10/rygepusu.jpg
    I have also noticed a slow down after I got the update. I've also noticed that the rotation from portrait to landscape and back has slowed considerable as well, if anyone has any suggestions they are greatly appreciated
    05-10-2013 12:04 AM
  3. Shimmy00's Avatar
    My battery life is better on 4.1.2. I did do a total reset after I got the update.
    05-10-2013 12:36 AM
  4. viper31573's Avatar
    mine is better also, though i didnt do a reset
    05-10-2013 01:13 PM
  5. viper31573's Avatar
    i dont let it get that far, but i think i could get 30+ hrs. i usually put it on charger around 18% and im already over 20 hrs at that point. also if im going to bed and im already under 50% then i charge it while i sleep
    05-10-2013 01:15 PM
  6. purwater's Avatar
    I haven't really noticed a change in my battery life, but mine too seems to lag now when changing from portrait to landscape mode. I get lag at other times too. Never had any lag at all before the update. It's really apparent when I'm trying to text.
    05-10-2013 01:23 PM
  7. DaRkL3AD3R's Avatar
    I don't believe this is from the update though. I am on 4.1.1 still using a custom ROM and I have the rotation bug where it either takes forever, or it simply doesn't work at all.
    05-12-2013 07:51 PM
  8. Neha Agarwal's Avatar
    Hi. I m having the same troubles with my note 2. The battery is draining after every 5 mins. And in 8 hrs olso it is getting only 50 percnt charge.
    Its not been a yr also. Nd such troubles are coming. Plz help
    07-26-2013 12:28 PM
  1. Battery life worse after JellyBean?
    By harold42483 in forum Sprint Galaxy Nexus
    Last Post: 01-28-2013, 10:47 AM
  2. Who's battery life sucks after 5.5.893 OTA?
    By jpvybes in forum Droid Bionic
    Last Post: 01-05-2012, 09:23 PM
  3. Battery life terrible after PBJ Kernal/Root
    By koala-czyk in forum Software Development and Hacking
    Last Post: 08-03-2011, 08:32 AM
  4. Battery life worse after 3.1
    By SlickMoney in forum ASUS EeePad Transformer
    Last Post: 06-05-2011, 06:54 PM
  5. Anyone else's battery life WORSE with 2.2?
    By beiermb in forum Verizon Droid Incredible
    Last Post: 09-04-2010, 11:35 PM
