1. hartzrj's Avatar
    Last night I woke up at around 3 am. To my suprise it looked like the sun had come out in my room. The Camera flash led on my note 2 had come on and lit the entire room up. I could not get it to shut off either unless I pulled the battery. It is still on right now. I have cycled power to the phone, hard and soft resets. Anyone have any suggestions or hear of this problem? I haven't found much on it. Been looking all day. My phone was very hot last night when it was on the charger as well. The led is much brighter when I plug it in, and like I said it won't go out unless I pull the battery. The minute I plug the battery back in, the led comes right back on :-( please help
    05-15-2013 02:44 PM
  2. SpookDroid's Avatar
    Does it come on with your phone off? If so, then something INSIDE the phone got shorted. I'd take it to be repaired.
    05-15-2013 02:55 PM
  3. hartzrj's Avatar
    Yes that's what I am afraid of. It stays on even with the phone powered down. I have no idea how it could have shorted. I am not one to tinker with my 2 month old expensive phones.
    05-15-2013 03:00 PM
  4. SpookDroid's Avatar
    If it's 2 months old at least you're still covered by Warranty. And hey, maybe it wasn't something you did, maybe it was a bad connector or something that was poorly soldered and was just waiting to snap, whether you used it or not...
    05-15-2013 03:04 PM
  5. hartzrj's Avatar
    Yeah, I was really hoping this wasn't a unique problem. With the new update and all. Thanks for your input. I will have to see what I need to do for warranty work.
    05-15-2013 03:09 PM
  6. SpookDroid's Avatar
    Also check your local Consumer Office laws... In some countries if your purchase was less than 3 months ago, it can't go to repair and has to be replaced with a new unit.
    05-15-2013 03:39 PM
  1. Turned NFC on last night for the first time...
    By dedduck0121 in forum Verizon Galaxy Note 2
    Last Post: 12-28-2012, 08:39 AM
  2. Replies: 9
    Last Post: 09-25-2012, 07:37 AM
  3. Replies: 6
    Last Post: 10-16-2011, 11:01 PM
  4. Replies: 9
    Last Post: 05-28-2011, 09:46 AM
  5. Compendium of Froyo Themes & Add-Ons | Last Update 2/15
    By ragnarokx in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 02-14-2011, 10:25 PM
