Your phone should work anywhere there are towers. You are not charged roaming ever. I am covered anywhere in the US. No issues. No need to be concerned
Your phone should work anywhere there are towers. You are not charged roaming ever. I am coveted anywhere in the US. No issues. No need to be concerned
They roam off of US Cellular if you're in one of the areas where US Cellular has coverage. It's all 1x roaming though, and shows as being connected to "Extended Network".
