07-02-2013 11:03 AM
37 12
tools
  1. mgftp's Avatar
    Every other android device I have had would see a charger by noon on most days and they all had extended batteries. My Note2 with stock battery has never been on a charger except for when I am sleeping.
    I am just absolutely blown away. I knew the battery was larger in the Note2 but I figured the larger screen size would negate most of the extra battery juice. But this phone's ability to retain a charge is just unmatched from anything else I have owned. And although I do turn off things like GPS, WiFi, and Bluetooth when they are not in use I have never done anything such a power saver mode or anything else that curtails the phone's performance. I am just amazed, this reason alone is worth updating to this device IMO.
    Just had to share one of my extreme joys of owning this phone for the past few weeks
    06-21-2013 07:03 AM
  2. VDub2174's Avatar
    That's great to hear!
    How long do you usually go between charges? I used to always say to myself that I would never get a phone as big as the Note 2 but I find myself looking at them more often.
    RazorDroid likes this.
    06-21-2013 07:34 AM
  3. lpt2569's Avatar
    I still charge every night because I use my Note as my clock/white noise machine while plugged into a charging dock next to the bed. I usually have about 4 or 5 hours of screen time usage a day, use full brightness with wifi on all day, and still have anywhere from 30 - 50% battery left at the end of the day. Of course everyone's usage will vary, and battery results will vary, but I never worry about not having enough battery left at any point in the day, regardless of my usage. And the only way to know if the size is an issue for you is to go to a store and try it out, ask them if they have a model not tethered to the security thing, so you can try it in your pocket. Once I did that, I knew this was the phone for me. I love the size, and I'm a small (5'5") dude. There is still not a single device on the market I like better at this point. The LG Optimus G Pro is sweet, and runs a very close second in my opinion, but I like the S-Pen and multi-view on the Note. Can't wait to see what they do with the Note3!
    06-21-2013 09:15 AM
  4. RazorDroid's Avatar
    ^This
    06-21-2013 09:16 AM
  5. mgftp's Avatar
    I am only charging it when I am sleeping so its off the charger 15-18 hours.
    Again, I am blown away by this because my other 3 Android phones with an extended battery would need charging by noon, I would almost never make it through a full day, if I did it would be because I literally didnt use the phone at all.
    Sent from my SCH-I605 using AC Forums mobile app
    VDub2174 likes this.
    06-21-2013 09:31 AM
  6. petaf's Avatar
    Agree with OP. There's nothing bad to say about this phone really.
    lpt2569, 808TBolt and Jude526 like this.
    06-21-2013 09:33 AM
  7. VDub2174's Avatar
    The only time I had an Android phone go that long was when I had my Gnex. It was rooted and had a custom kernel and lasted about 20+ hours but I wasn't using that as much as my HOX+. I might have to look into the Note 2.
    06-21-2013 09:42 AM
  8. JoeyyNY's Avatar
    I charge over night start my day at 100% by noon ill be on like 30% love my note 2
    Sexy Note II
    06-21-2013 09:48 AM
  9. anon(394005)'s Avatar
    Completely agree! It's refreshing to not worry about battery life. Even when it gets down to 30% or less, you know you've got a while to go yet. On previous phones, I'd be planning to swap batteries or looking for a charge. It's even sweeter having the option for a fully charged spare battery to get you back to 100% charge in minutes.
    IMHO, this phone has the trifecta: battery life, 5.5" screen and S-Pen! No other phone can compete. It's game over man, game over!
    lpt2569, limitbreak09 and 808TBolt like this.
    06-21-2013 10:18 AM
  10. TabGuy's Avatar
    I charge every night because it's convenient. Yesterday I glanced at the battery page in settings and after 7 hours 37 minutes I still had 79% battery left. That included 2 hours 16 minutes at screen time. I have the stock battery and always have screen at full brightness.
    Right now I'm at 96% after 2 hours 2 minutes.
    The stock battery is 3100mah battery. There are also 6200 and 9300 mah batteries available. The ZeroLemon 9300 mah battery, which I also have, will run the phone for 3-4 days. I get about 14 hours of screen time but if you turn the screen brightness down some you can easily get 20 hours of screen time. That battery adds some bulk but it doesn't have to be your daily driver, you can just use it for places where you can't get to a power plug. Best part is that it's only $40.
    lpt2569 likes this.
    06-21-2013 10:24 AM
  11. msndrstood's Avatar
    I have the Gnex as well as the Note 2. I have an extended battery 3800mAh on the Gnex and the Note with stock battery still out lasts the Gnex. Here's my best stats for the Note 2, GPS off, BT off, on wifi....
    What?! ... I'm msndrstood.
    via Note II
    lpt2569 likes this.
    06-21-2013 10:26 AM
  12. TabGuy's Avatar
    I keep mine charged as much as possible because of these two words: Hurricane Sandy. I saw many people interviewed after that hurricane and many of them lamented that they didn't have a full charge on their cell phone when the hurricane hit. So, even with long battery life I recommend that you keep it plugged in whenever you can.
    .jpg, 808TBolt, petaf and 2 others like this.
    06-21-2013 10:26 AM
  13. msndrstood's Avatar
    I have 2 stock batteries, just ordered a 4500 mAh external charger (now I have 2) and I also just ordered a 6200 mAh extended battery. Plus I have a UPS to charge the external batteries. I'm obsessed with being out of touch since we ditched our house phone. We're in PA but in the boonies and when our power goes out, which it does at times for no reason, it can be out for 12+ hours. I don't take any chances.
    via Note II
    06-21-2013 10:33 AM
  14. coxley24's Avatar
    Bar none one of the best phones/battery I've ever had...
    msndrstood and lpt2569 like this.
    06-21-2013 11:52 AM
  15. VDub2174's Avatar
    I ordered a Note 2 and I blame everyone in here for "making" me do it
    06-22-2013 11:34 AM
  16. VDub2174's Avatar
    Because of Hurricane Sandy I got a solar powered charger.
    msndrstood likes this.
    06-22-2013 11:35 AM
  17. lpt2569's Avatar
    Awesome! Welcome to the club, pretty sure you will not regret it at all.
    06-22-2013 12:17 PM
  18. VDub2174's Avatar
    I couldn't not buy it after seeing what everyone was saying about the battery
    lpt2569 and msndrstood like this.
    06-22-2013 12:50 PM
  19. Jude526's Avatar
    Love this phone. No regrets
    sent from my amazing Note2
    petaf, msndrstood and 808TBolt like this.
    06-22-2013 09:17 PM
  20. pool_shark's Avatar
    I charge mine whenever possible just because there is no reason not to.
    I'm not one of those who wants to see how long my device can go on a single charge.
    Mine charges in the car, at work, or just sitting around the house.
    I'm out on my deck now drinking my morning coffee, it's charging.
    06-23-2013 08:57 AM
  21. jrsharp70's Avatar
    I got mine from amazon yesterday for $80 on contract. I kept hearing about the battery and screen size and had to try it.
    All I have to say is... Awesome...
    VDub2174 and lpt2569 like this.
    06-23-2013 09:09 AM
  22. anon(394005)'s Avatar
    That sounds like a lot of wear and tear on the phone (ex. charging port and increased heat build up internally), not to mention being tethered to a cord (or some power source). IMO, kind of defeats the purpose of having a mobile (keyword being mobile ) device, as well as not fully utilizing the Note 2's awesome battery life.
    I'd rather have a spare battery and swap out as needed (phone is rarely if ever connected to a charger). No need to worry about trying to stay topped off and it keeps the phone unencumbered as it's not tethered to anything. It's also a lot cheaper to replace a worn battery door if needed (although easy to mitigate by being careful taking it off/on). Anyway, different strokes for different folks.
    06-23-2013 09:29 AM
  23. mgftp's Avatar
    I need a dock.
    06-23-2013 09:42 AM
  24. GregMargie's Avatar
    I too agree.... the battery on the Note 2 is amazing! Kind of scary that I rarely even look at my battery % anymore because this phone has spoiled me! I start out about 6:30am using my phone...... lots of calls, lots of email, texts, leave FB connected, play some words w/friends, gps and a few other things and my battery is usually anywhere between 40-60% come 5-6pm!! Outstanding! Love this phone!
    Margie
    Sent from my Galaxy Note 2
    06-23-2013 10:13 AM
  25. pool_shark's Avatar
    Ah yes, the myths of over charging damages. I've done it with every phone I've ever owned since the 90's. Never once replaced a battery or phone due to charging damage.
    Tethered to a cord. I'm in the car, not using it much anyway. At work, I work with computers, sitting at my desk all day, it sits on the desk with me. At home, I'm sitting on the deck, watching TV, reading, or sleeping, the cord is 6' long, not in the way at all.
    There is no reason to see how long my battery can last when I'm usually near an outlet.
    I'd rather charge it whenever I want rather than turn off features, or not use the device for fear of the battery not lasting all week.
    I use my phone more than I use my laptop, of course I'm going to keep it charged when I can.
    Shawn_S and .jpg like this.
    06-23-2013 10:18 AM
37 12
  1. Why am i getting sucky battery life on almost any rom i try
    By kingseanrocks in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 06-05-2013, 03:56 PM
  2. Replies: 10
    Last Post: 12-12-2012, 11:41 AM
  3. All this crying on the battery life on the first true 4G mobile
    By Chilly818 in forum Thunderbolt Accessories
    Last Post: 04-04-2011, 12:59 PM
  4. All this crying on the battery life on the first true 4G mobile
    By Chilly818 in forum Verizon HTC Thunderbolt
    Last Post: 04-04-2011, 11:13 AM
  5. Battery Life on the Droid
    By pstellato73 in forum Motorola Droid
    Last Post: 11-05-2010, 10:41 AM
