1. FlyingBackwards's Avatar
    why does the Verizon Galaxy Note 2 battery have a different part number than the GSM Note 2?
    EB595675LZBXAR for Galaxy Note II Standard Battery (3100mA) (Verizon & US Cellular)
    Link to Samsung website
    EB595675LABXAR for Galaxy Note II Standard Battery (3100mA) GSM version
    Are these two batteries interchangeable?
    Thanks!
    06-21-2013 04:05 PM
  2. jweimn's Avatar
    Thanks!
    When looking to get a spare battery for mine I know it said somewhere that they are not and the Verizon one is specifically for Verizon not gsm. Still not sure why
    Sent from my HTC One using Tapatalk 4 Beta
    06-21-2013 04:13 PM
  3. kgk1985's Avatar
    Pretty sure they can be swapped. The part numbers inside the links are the same. They only go to the L on both.
    sent from Galaxy Note 2
    06-22-2013 03:31 AM
  4. sux2bu's Avatar
    They are the same. I bought the spare battery and charger from Samsung and that battery also has a different part number than my original. If they were not interchangeable then they would have to sell a spare battery/charger kit for each carrier, which they don't.
    06-24-2013 03:08 PM
  1. Replies: 9
    Last Post: 11-18-2012, 10:32 PM
  2. Aluminum battery door for the Verizon Galaxy Nexus (i515)
    By Linebarrel86 in forum Verizon Galaxy Nexus Accessories
    Last Post: 08-07-2012, 03:38 AM
  3. Replies: 6
    Last Post: 11-12-2010, 10:17 AM
  4. Why does no phone with 2 flashes have one on each side of the phone?
    By IceBone in forum The Android Central Lounge
    Last Post: 10-29-2010, 08:35 AM
  5. Replies: 0
    Last Post: 12-31-1969, 07:00 PM
