My Verizon shows 10gb higher data usage than "Data Usage" in the Settings
The my Verizon widget shows 10gb higher data usage than the "Data Usage" in the Settings menu. Granted, this is only 1-2% of my usage, but I wonder why it is off by 10gb,which seems like a lot.
Sent from my BN NookHD+ using Tapatalk 2
Re: My Verizon shows 10gb higher data usage than "Data Usage" in the Settings
Well, all I can think of is, if you've factory reset or reflashed a ROM or wiped your device then your usage values would change, it would be reset to zero, atleast thats what happens to me, so maybe you accidentally wiped or reset your phone during this billing period?
Originally Posted by
devchaube15 Well, all I can think of is, if you've factory reset or reflashed a ROM or wiped your device then your usage values would change, it would be reset to zero, atleast thats what happens to me, so maybe you accidentally wiped or reset your phone during this billing period?
No, i have not. I checked the data usage in the settings and it shows usage from the first day of the cycle
Sent from my Verizon Samsung Galaxy Note II
thats strange. both my widget and data usage in settings are the same
How the hell do you use 60 GB of data a month
Sent from my HTC One using AC Forums mobile app
dpham00 The my Verizon widget shows 10gb higher data usage than the "Data Usage" in the Settings menu. Granted, this is only 1-2% of my usage, but I wonder why it is off by 10gb,which seems like a lot.
10GB is 1=2% of your monthly usage? You're using a terabyte of data? How?
fillossofer 10GB is 1=2% of your monthly usage? You're using a terabyte of data? How?
Depends on the month, I haven't gotten to a tb yet. My max is close to 700gb .
Lots of streaming and downloading.
Dude I'm being honest that's not healthy at all you know this right?
dpham00 Depends on the month, I haven't gotten to a tb yet. My max is close to 700gb .
Good God, man. I don't think I've ever even used that much data in a month through my Cable Modem! Nice to see someone is getting their money's worth, though. Honestly I am surprised Verizon hasn't cut you off.
