1. donb2010's Avatar
    I just got a note II, I noticed that when I press the power on/off button it turns off immediately,but takes a full 2 seconds to turn on again. Is it me or is that a little slow? I've had a few android phones and they would turn on/off immediately when the power button is pressed. Any thoughts?
    07-08-2013 10:37 AM
  2. chuckh0308's Avatar
    Mine comes on instantly, FWIW.
    07-08-2013 03:37 PM
  3. donb2010's Avatar
    Starting to think it's just my phone.
    07-08-2013 04:23 PM
  4. universeand's Avatar
    From a full power off mine also takes a 1-2 seconds to see the Galaxy Note II logo and has since I got it 8 months ago.
    07-08-2013 09:12 PM
  5. tfly212's Avatar
    That is what is known as wake lag. Some devices seem to feel it more than others. If it really bothers you there is a root method to fix it....essentially keeps one of the cores active all the time so it wakes instantly. Google wake lag fix note 2 and you can find the mod.
    Sent from my SCH-I605 using Tapatalk 2
    07-08-2013 10:16 PM
  1. Replies: 2
    Last Post: 07-11-2013, 11:35 PM
  2. App2SD on my Verizon S4
    By mannyvigi1985 in forum Verizon Samsung Galaxy S4
    Last Post: 07-08-2013, 10:17 AM
  3. Tried to install clockwork now triumph just vibrates continuously when i try to power on
    By mermaidgrl in forum Motorola Triumph on Virgin Mobile
    Last Post: 07-08-2013, 01:05 AM
  4. good deal on woot.com!
    By gamefreak715 in forum ASUS Transformer Pad Infinity 700
    Last Post: 07-07-2013, 10:20 PM
