1. heggood's Avatar
    Help! I have a note 2 that is stuck on the logo screen, it will not boot, nor can I boot into recovery, my only option is download mode. I have try flashing back to stock w/ Odin but it fails. I have tried the note2 toolkit but its stuck on " waiting for USB debugging to be enabled". How can I enable this without being able to access my phone settings? Thanks!
    07-08-2013 12:55 PM
  2. iFebby's Avatar
    I don't believe you can't and the fact it isn't booting into android means USB debugging cant be accessed if I remember correctly. ADB access could be possible.
    Have you considered a JTAG service to fixed the bricked device since I assume you flashed something not meant for your phone or how did the brick happen?
    If all fails you could use this JTAG service
    http://item.mobileweb.ebay.com/viewi...d=281111151388
    I've used it previously and is cheap. There is also mobiletechvideos.
    Sent from my SGH-I337 using Tapatalk 2
    07-08-2013 01:25 PM
  3. titans30dude's Avatar
    If your bootloader is unlocked and you flashed a rom usin odin you will brick your device...only use odin to go back to stock if you unlocked your bootlader
    Sent from my SCH-I605 using AC Forums mobile app
    07-18-2013 11:23 PM
  4. gollum18's Avatar
    If you were running the stock kernel when this happened there is unfortunately no way you can enable USB debugging. As it is disabled by default in all stock kernels. The above mentioned is your only way to fix it.
    Another question though; can you access recovery?
    07-18-2013 11:51 PM
  1. How to upload photos from galaxy s4 into iPhoto on my iMac?
    By 420benz in forum Samsung Galaxy S4
    Last Post: 09-10-2013, 12:21 PM
  2. Nexus 10 going to sleep while streaming Google Play Music
    By happybuddha in forum Google Nexus 10 Tablet
    Last Post: 08-26-2013, 12:24 PM
  3. Power on/off
    By donb2010 in forum Verizon Galaxy Note 2
    Last Post: 07-08-2013, 11:16 PM
  4. Please. Help. I think I need to flash a different ROM, but I'm not sure how
    By garybeckvt in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 07-08-2013, 03:25 PM
  5. Will you use the 4.2.2 lock screen on the One?
    By dd0yl3 in forum HTC One M7
    Last Post: 07-08-2013, 01:47 PM
