1. MissyHaney's Avatar
    I use my Verizon Samsung Galaxy Note 2 phone with AT&T GoPhone prepaid SIM card(GSM). My phone is not rooted. All I had to do was to type in AT&T's APN. (just needed to enter Name: "ATT" and APN: "wap.cingular" and save the new APN profile. Data worked perfectly. I have the AT&T Gohpone Prepaid $60 unlimited voice/text with 2GB data plan.
    Here's my question: The status bar says 3G when I'm home, but when I'm in the downtown area, it switches to H+.
    I figured AT&T 3G means the same thing as it does on Verizon 3G.... but what is this H+ supposed to mean?
    07-30-2013 03:26 PM
  2. dpham00's Avatar
    H+ indicates HSPA+. Att considers it to be 4g, though it isn't as fast as 4GLTE
    Sent from my Verizon Samsung Galaxy Note II
    07-30-2013 03:37 PM
  3. MissyHaney's Avatar
    how much faster is HSPA+ supposed to be? (compared to regular 3g) I sure don't notice a big difference when using it on my Verizon Galaxy Note 2.
    More importantly, I'm guessing that the Verizon Samsung Galaxy Note 2 won't be able to pick up AT&T's true 4G LTE signals. Or am I wrong? I can't test this because AT&T doesn't have 4G LTE in my town yet... will try it when I'm in NYC next week.
    07-30-2013 04:14 PM
  4. Paul627g's Avatar
    I've seen plenty of impressive speed tests using HSPA+. Blows the doors off anything Sprint has on 3g and even some areas with Sprint LTE
    Sent from my Nexus 7 using AC Forums mobile app
    07-30-2013 04:17 PM
  5. MissyHaney's Avatar
    were these speed tests done on Verizon Galaxy Note 2 using AT&T GSM SIM cards?
    07-30-2013 04:28 PM
  6. MaxBuck's Avatar
    When I used my phone in Austria and Czech using foreign SIMs, I experienced excellent data speeds on both 3G and H+ signals. Much faster than I see on 3G signals here in the States. Didn't run any speed tests, though.
    07-30-2013 05:42 PM
  7. MissyHaney's Avatar
    I will be in Prague at the end of September. Could you tell me where you bought the prepaid SIMs?
    Thanks!
    07-30-2013 06:09 PM
  8. MaxBuck's Avatar
    Thanks!
    There's a mall right next to the Anděl metro station where there are O2, T-Mobile and Vodaphone stores.
    07-30-2013 11:47 PM
  1. My Calendar with CM 10 ?
    By darjay in forum AT&T Galaxy S III
    Last Post: 08-02-2013, 07:01 PM
  2. Phone stopped sending/receiving calls and texts
    By Francis Liston in forum HTC One M7
    Last Post: 08-01-2013, 02:50 PM
  3. How much RAM do you usually use up?
    By coldjeanz in forum HTC One M7
    Last Post: 07-31-2013, 11:10 AM
  4. My phone upgrades are available, what are my options?
    By mostd0pe in forum General Carrier Discussion
    Last Post: 07-30-2013, 03:08 PM
  5. Samsung Galaxy Note II - Need urgent help
    By Veenamra P in forum General Help and How To
    Last Post: 07-30-2013, 02:48 PM
