1. Reharper72's Avatar
    I can't connect to my home Wifi anymore. I get a saved/secured message but no connection. When it does connect occasionally, nothing works. It just freezes. I have done 2 factory resets and nothing helps. Any ideas?
    08-02-2013 10:13 PM
  2. Golfdriver97's Avatar
    Try going into Settings>Apps>All Apps and down to WiFi direct share. Click on it, and then click clear data. This will cause the password to be erased, so you will have to reenter it.
    08-02-2013 11:54 PM
  1. SwiftKey cursor issue, help?
    By HPferoxCraft in forum Samsung Galaxy S4
    Last Post: 02-21-2017, 01:22 PM
  2. Issues with the new 4.1.2 ATT update?
    By shamelin73 in forum AT&T Galaxy S III
    Last Post: 01-16-2014, 10:29 AM
  3. gps must the wifi be on when using
    By kaschiro in forum Samsung Galaxy Tab 2 10.1
    Last Post: 08-04-2013, 11:30 AM
  4. External keyboard bluetooth issue
    By attyple in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-02-2013, 08:47 PM
  5. Wifi ups and downs
    By xweb10 in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-02-2013, 02:33 PM
