1. funnyguy337's Avatar
    Hello Everyone,
    My name is Lee,and my Verizon bill is ridiculous.
    But luckily I have an awesome friend with ATT and a spare phone line in which ill use.
    So how can I cancel my Verizon account,and use my Galaxy Note 2 on ATT?
    Please help,I've been looking and looking for an answer soo long.
    Thank you in advance
    Lee
    08-20-2013 10:21 PM
  2. Bobman's Avatar
    I guess you could try putting your friend's ATT sim card in your phone and see what happens. From some of these other posts about global use, it may just work. Not sure about your data speed though.
    08-21-2013 07:44 AM
  3. MissyHaney's Avatar
    with my Verizon Galaxy Note 2, data speed is pretty fast on AT&T HSDPA network(faster than 3G)....
    I've been using my Verizon Galaxy Note 2 with AT&T prepaid GoPhone SIM card for a few months. ($60 unlimited voice/text and 2GB data)
    Try this thread:
    http://forums.androidcentral.com/ver...ns-update.html
    08-21-2013 08:28 AM
  4. jharo's Avatar
    I've read that there's a hardware hack that will let you use it on ATT.
    08-21-2013 11:43 AM
  5. Shadowtc's Avatar
    I think your talking about changing the frequencies but its not needed I think
    08-21-2013 11:51 AM
  6. MissyHaney's Avatar
    a hardware hack? why? there is absolutely no need to do anything....
    let me put it simply... go to a Verizon store and buy a brand new Verizon Galaxy Note 2 today,
    go down the block to the AT&T store and get an AT&T prepaid SIM card... insert the card
    into your Verizon Galaxy Note 2 and you can immediately start using it on AT&T's network
    for voice and text. To use data, just enter wap.cingular in the APN setting... simple as that.
    08-21-2013 11:54 AM
  7. jharo's Avatar
    It's over in XDA, in the video that shows how to root. He just mentions it, but really doesn't show how.
    08-21-2013 04:27 PM
  8. funnyguy337's Avatar
    I tried putting the ATT sim card she had in a really old school phone,but the sim card was too big.
    Now if I have her get a sim card,does she need to specify its formy Verizon Galaxy Note 2?
    Or is the ATT sim card smaller now? Or just for smart phones?
    Thank you soo much, you have helped alot.
    I hope im only a step away..Lee. Now does a sim card cost or get free?
    08-21-2013 05:48 PM
  9. MissyHaney's Avatar
    Here's what you need to do:
    (1) go to a corporate-owned AT&T store
    (2) ask for a micro-SIM card (tell them it's for a Galaxy Note 2)
    (3) they'll give you one for free... all the AT&T stores in my area give them out for free
    (4) go home
    (5) log into AT&T's GoPhone prepaid activation page
    (6) enter your zip code, this will determine which area code you get... use a different zip code if you want area code somewhere else
    (7) choose a 4-digit PIN
    (8) pick a prepaid plan.. from 25-cent/minute all the way to $60/month unlimited voice/text with 2GB data
    (9) add money... not required if you just want to see if the SIM card works in a Verizon Galaxy Note 2
    (10) insert the micro-SIM card into the Verizon Galaxy Note 2
    (11) power on the phone
    (12) you will now see "AT&T" when you pull down the notification menu
    (13) for data, enter "wap.cingular" in APN menu
    (14) done
    I hope this helps.
    mrbingo likes this.
    08-21-2013 07:10 PM
  10. GeekCop's Avatar
    Sounds like an awful lot of work to use a Note 2. Either you can afford one or you cant
    10-14-2013 10:41 PM
  11. Bill P's Avatar
    Thanks MissyHaney for a good job preparing the instructions.
    10-16-2013 09:28 AM
  12. ladybridge7's Avatar
    Do in need to call AT&T customer service to get my SIM card transfer to my Samsung galaxy note 2 phone? and I have a AT&T GoPhone SIM card.
    09-21-2016 02:25 PM
  13. Ashley Chambers's Avatar
    MY phone for some reason want work with other provides even after changing the networsettings any suggestions
    11-07-2016 11:02 PM
  14. TheProuddad's Avatar
    I don't believe that you can switch from CDMA (Verizon) to GSM (AT&T) or vice-versa with older phones like the Note 2.
    11-09-2016 05:21 PM
  1. Samsung galaxy note wont charge
    By johnmoore4 in forum AT&T Galaxy Note
    Last Post: 08-25-2013, 12:28 PM
  2. Video calls possible between Android and iOS?
    By monkmullen in forum General Help and How To
    Last Post: 08-21-2013, 10:23 PM
  3. How can I use my verizon galaxy note 2 and switch to att?
    By funnyguy337 in forum Verizon Galaxy Note 2
    Last Post: 08-21-2013, 02:45 AM
  4. Story of my Pebble
    By BasPilot in forum Pebble Smartwatches
    Last Post: 08-20-2013, 09:51 PM
  5. Incoming call while using GPS.
    By ddiehl in forum AT&T Galaxy S III
    Last Post: 08-20-2013, 09:35 PM
