1. burnsidej92's Avatar
    So, I was looking on Amazon for a new charger because mine was bent on the tip where it plugs into the phone. l read that I need a 2 amp charger to replicate the same charge time as my OEM charger. Does the cable have anything to do with it?
    My wall adapter works fine it's just the USB cable. Do I need to get a specific USB cable for 2 amp charging or will any work?
    Thanks!
    09-11-2013 01:04 AM
  2. Paul627g's Avatar
    No the cable shouldn't have any bearing on the amps going thru. Sure you want a good USB cable but the wall adapter is controlling the amps.
    09-11-2013 10:05 AM
  3. MaxBuck's Avatar
    Actually, some USB cables are not designed to accept 2-amp current, so I'd recommend getting either a Samsung, Verizon or other cable that is verified to carry that amperage. I've had charging failures using generic USB cables.
    09-11-2013 06:21 PM
  4. LIncolnpondlover's Avatar
    I bought a 2amp charger set at Walmart. A wall plug adapter, car charger adapter and the USB cord for less than $20. It works great!
    09-11-2013 08:52 PM
  5. burnsidej92's Avatar
    Thank you! Appreciate the help
    09-14-2013 04:16 PM
  6. Mbode1's Avatar
    Never had any problems using generic cables. Not to say you can't but, never have. I buy all my cables from Monoprice and they seem to be of excellent quality. Maybe that makes a difference.
    Sent from my recliner, using my arthritic thumbs. (being helped by the Abby dog who is reading from my shoulder)
    09-16-2013 10:39 PM
  7. dpham00's Avatar
    Monoprice are pretty decent quality considering the price, and work great.
    The issue is some generic cables won't support 2a charging. If you buy a good quality generic then you will be fine.
    Sent from my Verizon Samsung Galaxy Note II via Tapatalk 4
    09-17-2013 10:59 AM
  8. MaxBuck's Avatar
    My point was to verify that the cable will accept the amperage; nothing more. Do you think doing so is a bad idea?
    09-18-2013 05:05 PM
  1. Replies: 3
    Last Post: 09-11-2013, 11:52 AM
  2. Verizon Note 2, plus cases, charger and 2 extended batteries
    By MikeLip in forum Marketplace Archive
    Last Post: 09-10-2013, 09:13 AM
  3. I'm looking for a long charger cable
    By Joaoakim in forum Samsung Galaxy S4
    Last Post: 09-09-2013, 03:40 PM
  4. no noise when plugging charger in
    By drich290195 in forum Samsung Galaxy S4 Google Edition
    Last Post: 09-06-2013, 03:41 PM
  5. Phone turns on sound after charger
    By lessthannick11 in forum Verizon Galaxy S III
    Last Post: 09-06-2013, 11:14 AM
