06-18-2014 11:25 AM
48 12
tools
  1. cbroussard99's Avatar
    I just got the update in San Diego...
    Sent from my SCH-I605 using AC Forums mobile app
    06-12-2014 12:14 PM
  2. aparker2005's Avatar
    So does nfc and Google wallet work now? I don't have the special sim card, just the original that came with the phone. Would love to use Google wallet again!
    06-12-2014 12:19 PM
  3. Nibs's Avatar
    Finished downloading! Haven't delved into it yet but I don't see much of a difference though
    06-12-2014 12:45 PM
  4. jlo3378's Avatar
    It allowed me to download wallet and set it up as a tap to pay option. Haven't tried it out in the real world, but it seems like it should work.
    06-12-2014 01:13 PM
  5. jlost's Avatar
    How is the update running for all? Any noticeable difference? Good or bad.
    06-12-2014 02:56 PM
  6. aparker2005's Avatar
    I've noticed somewhat better battery life so far. A little snappier as well
    im50un1que likes this.
    06-12-2014 03:13 PM
  7. jlost's Avatar
    I've noticed different fonts, that all I can see. My attention is on the world cup. (GO ITALY) We all know USA won't make it far lol.
    06-12-2014 03:19 PM
  8. api7342's Avatar
    No real difference in performance or battery life so far.
    06-12-2014 03:51 PM
  9. jlo3378's Avatar
    It seems to be running ok but there are little things that will take getting used too.
    1. Emoticons.
    2. Seems Wallet will be usable for tap and pay.
    3. s pen input seems more accurate for writing with a different/new interface.
    4. Wifi seems to be more stable. Previously it seemed like it would drop connection for no reason.
    5. Able to print to my Canon printer without using printershare.
    Dislikes:
    1. Constant NFC icon at top.
    2. Can't hide apps in the app drawer.
    3. I have gear watch and emails are being "difficult"
    4. Google Now, when I say "Ok Google" it's taking 3 to 5 seconds before I can talk/give command.
    Too early to know about battery life. Would love to hear others opinions.
    Sent from my SCH-I605 using Tapatalk
    06-12-2014 04:15 PM
  10. KBlack2595's Avatar
    I tried it and they both work haven't tried google wallet in the filed yet though
    06-12-2014 04:25 PM
  11. maddiealan's Avatar
    I received the update, and the phone does seem a little faster. Can't decide about battery life yet, but the good news is that it's not worse. One thing I notice is that Smart Stay is working again! After the last two updates I couldn't get it to work. And they removed the little eye in the notification area, which is great.Still playing around with the phone.
    06-12-2014 06:34 PM
  12. jpriest007's Avatar
    Yes nfc payments work now with Google wallet.
    Posted from my Galaxy Note 2 via Android Central App
    06-12-2014 08:02 PM
  13. YeOldeGoat's Avatar
    How long does it take them usually to make the update available on the windows Verizon Update Manager? Mine says up to date still on 4.3.
    06-13-2014 12:24 PM
  14. jpriest007's Avatar
    It is usually available first on the update manager
    06-13-2014 02:15 PM
  15. YeOldeGoat's Avatar
    Mine still says up to date on kies and verizon upgrade assistant on 4.3 even after a factory reset. Has anyone's worked or is this my problem? I cant get OTA so I'm waiting for the wired upgrade.
    06-13-2014 04:40 PM
  16. jlost's Avatar
    I couldn't get the update through the PC. I kept getting the phone is up to date. So then a little later I went to about phone and searched for the update manually and there it was, sitting waiting to be downloaded.
    06-13-2014 05:53 PM
  17. kach474's Avatar
    My wife's note 2 (in western NY) got it. My question is how do you disable the notification? In my old Motorola you can disable the "updater" and it won't constantly bug you to update. We don't want the update. Locking down the SD card is one more step Google is taking to being apple. Anyway anyone know how to disable it?
    06-17-2014 06:03 PM
  18. 808TBolt's Avatar
    i'm only skimming on your post since i'm still at work
    but could you elaborate on "locking down the SD" card please?
    haven't really been on these forums in a little while
    06-17-2014 08:15 PM
  19. kach474's Avatar
    06-17-2014 10:26 PM
  20. ezrevo2010's Avatar
    Just finished downloading ota update 4.4.2 on my note 2...
    06-18-2014 01:35 AM
  21. BlkWolf03's Avatar
    Woke up this morning and it was sitting there waiting to be installed. Hope it helps the battery life some.
    Edit:
    The wifi & battery icon n the notification is different and GPS has changed to Location in the quick menu ... the fonts seem to be a bit smaller in the notification too but that could just be my eyes lol
    06-18-2014 08:33 AM
  22. Neofite's Avatar
    I'm updating right now. I'm in Mayrland.
    06-18-2014 09:32 AM
  23. 1812dave's Avatar
    downloading now. wishing myself luck!
    06-18-2014 11:25 AM
48 12
  1. KitKat 4.4 for HP Slate 7?? Is this for real?
    By sirzune in forum HP Slate 7
    Last Post: 02-26-2015, 02:01 PM
  2. Replies: 6
    Last Post: 01-21-2015, 04:33 PM
  3. native S-pen note taking app?
    By theinvisibleheart in forum Samsung Galaxy Note Pro 12.2
    Last Post: 06-15-2014, 06:02 PM
  4. Which mobile is better Iphone 5 or Samsung galaxy S4?
    By ChristopherRParker in forum Samsung Galaxy S5
    Last Post: 06-14-2014, 04:02 AM
  5. Verizon Wireless and OpenVPN
    By Davel23 in forum Samsung Galaxy S5
    Last Post: 06-13-2014, 08:57 AM
