I'm wondering if anyone else has seen this problem.
After the Kit Kat update, my Note 2 works just fine.
However, wifi sometimes doesn't turn on after the phone wakes up. If I go into the wifi menu under settings, I can't change between on and off. The button is just greyed out. The only way around it is to turn airplane mode on and off and then go back into the wifi menu. At that point, wifi can be turned on again.
I have already tried restoring the phone completely twice. The issue still persists.
Any advice appreciated!
