1. yourphonemyphone's Avatar
    My Verizon Galaxy Note 2 used to automatically go into MTP mode whenever I connect it to a PC.
    It allowed me to immediately start copying to or from the phone to the PC.
    I reset the phone to factory default after the 4.4.2 update. Since then, the phone always connect
    in installer mode. I have to manually check the MTP box every single time that I connect it to a PC.
    Is there a way to make it go into MTP mode all the time?
    THanks!
    07-25-2014 08:06 PM
  2. Golfdriver97's Avatar
    Go to Settings>storage>menu>USB computer connection. See if that works.
    Signed, an M8, Liquidsmooth, and the AC Forums App
    07-25-2014 08:16 PM
  3. yourphonemyphone's Avatar
    Thanks! Unfortunately, there is no such setting in the VZW Note 2's menu.
    07-25-2014 08:41 PM
  1. How To Get Popup Notifications on Lock Screen???
    Last Post: 09-07-2014, 03:10 PM
  2. Horribly annoying icon to unknown app!!! HELP!!!
    By Txrd999 in forum Ask a Question
    Last Post: 09-07-2014, 01:18 AM
  3. Note 3 Heating and Serious Battery Drain Issues :(
    By Rohan Kapadia in forum Samsung Galaxy Note 3
    Last Post: 07-30-2014, 07:47 AM
  4. How to take the best phone in the world and turn it into crap
    By Babbah Shanaba in forum Verizon Galaxy Note 2
    Last Post: 07-29-2014, 08:51 PM
  5. Google Camera on S3 - No HDR Mode?
    By bml203 in forum Samsung Galaxy SIII I9300
    Last Post: 07-25-2014, 07:11 PM
