1. jlost's Avatar
    Does anyone know of a replacement battery for the note 2 that is "slim extended" that will fit the OEM case. If not I can just get the OG battery. I think I may need a replacement as my battery is about 1yr 8mths old and it is being used more than it should. I even killed it to the point of the phone having to shut off and charging it back fully. Thanks.
    10-20-2014 01:17 PM
  2. srkmagnus's Avatar
    I don't think you'll find a larger battery that will fit the existing case. Let us know how getting a replacement goes.
    10-20-2014 01:45 PM
  3. jlost's Avatar
    Will do. It will take a few as I am going to need to order it off Amazon.
    10-20-2014 03:07 PM
  4. jlost's Avatar
    Ok I ordered and received another battery from Amazon: http://www.amazon.com/gp/aw/d/B00A31...ref=mp_s_a_1_8 I'll need a few days to know if it is better or not.
    10-23-2014 02:04 PM
  5. jlost's Avatar
    It seems that this battery is lasting longer. When I take it off of the charger it doesn't go down to 98% in a minute like the old one did. I'm happy so far.
    10-27-2014 08:19 AM
  1. Microsoft Office Mobile - Incompatible with Note 4?
    By wsrobert in forum Samsung Galaxy Note 4
    Last Post: 12-15-2014, 09:59 AM
  2. Note 3 & keyboard lag
    By PoisonDarts8714 in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-06-2014, 10:19 PM
  3. Ridiculous charging time with NEW battery
    By Olivia Bowers in forum Samsung Galaxy SIII I9300
    Last Post: 10-22-2014, 07:33 PM
  4. Best Note 4 screen protector? (Not glass)
    By phantomog in forum Samsung Galaxy Note 4
    Last Post: 10-20-2014, 11:44 AM
