1. NHBass39's Avatar
    I want to upgrade to kitkat, but after I unrooted I go to software updates and it hangs then goes back to the main screen. Any ideas. I did not format. Please help!
    02-04-2015 10:26 AM
  2. NHBass39's Avatar
    Anyone?
    02-05-2015 03:27 AM
  3. pool_shark's Avatar
    You want to take the OTA update to 4.4?
    Are you aware that it limits apps writing to the sd card?
    You would be better off installing a 4.4 ROM if you unlocked your bootloader.
    Aside from that, if your device status says modified or the Knox counter was tripped that can cause the update to fail.
    02-05-2015 08:31 AM
  4. NHBass39's Avatar
    I unrooted already is there any way you could help me get, 4.4 and provide a good rom?
    02-05-2015 08:53 AM
  5. pool_shark's Avatar
    02-05-2015 10:44 AM
  6. NHBass39's Avatar
    Can you walk me step by step. I am not familiar with installing a rom
    02-05-2015 02:55 PM
  7. pool_shark's Avatar
    I don't know if your bootloader is unlocked or not.
    If it isn't and you're on 4.3, you can't unlock it without going thru quite a bit.
    Here is a link for all the info you need.
    Verizon Galaxy Note II Android Development - XDA Forums
    02-05-2015 06:10 PM
  1. Help me diagnose sudden, drastic battery drain
    By whitenack in forum General Help and How To
    Last Post: 02-04-2015, 04:57 PM
  2. Can I get weather updates without using my GPS?
    Last Post: 02-04-2015, 12:06 PM
  3. Unable to reinstall Backed up OALD app- Help!!!
    By nitu12345 in forum General Help and How To
    Last Post: 02-04-2015, 10:15 AM
  4. Replies: 0
    Last Post: 02-04-2015, 08:54 AM
  5. Can I get some help with my Galaxy S4 SCH-I545L jfltelra?
    By Jacob Drury in forum Samsung Galaxy S4
    Last Post: 02-04-2015, 07:09 AM
