1. bvitale's Avatar
    Hey all,
    So I have had my Note 2 since a month before launch. I did get a refurbished one under warranty 6 months ago. Out of nowhere the phone would just freeze in the screen off position. I called support enough they sent me a replacement free of charge. So now that I essentially have a new phone (Runs great) I would like to get a battery to bring it back to the beginning days of 20+ hours of moderate use. I am currently down to 13 hours before needing the charger. I laugh because my Thunderbolt never saw 13 hours when new and on standby HAHAHA. So anyway, onto my question. I want to get a new battery for the phone. I want something that doesn't need a different cover. I don't want to spend a lot. And I would also like it to be from a Amazon Prime seller. I know I can get the OEM battery for around $9 up to $20. Are there other brands and bigger capacities that I should look at? Or just go for the original? I don't want to get extended if the back of the original case doesn't fit.
    Thanks,
    Brandon
    04-13-2015 09:32 AM
  2. Golfdriver97's Avatar
    Once you go with a bigger capacity, you would have to get a different back plate. I would get several OEM batteries if you don't want to mess around with a new plate.
    04-13-2015 09:56 AM
  3. bvitale's Avatar
    Yea. I figured as much. Think I'll just get one. I have gone 2 years using one and its just starting to get old. Went from 20+ hours to 13ish. Still not bad. So I can get one oem and keep my original as backup if needed.
    04-13-2015 10:16 AM
  4. Rukbat's Avatar
    1. Keep it above 40% charge. Once it gets down to 40%, plug it in. That'll prolong the life. (I have some 10 year old batteries that still give me about 95% capacity.)
    2. I like Anker. They're an Amazon seller. If you get the 2 battery and charger combo, you can charge both batteries at the same time, so if you get down to 40% and swap batteries, then get down to 40% on that one, both of them get charged over night. They're normally about $25 for the combo.
    04-13-2015 01:36 PM
  1. Severe battery drain (bought new battery today also)
    By VexExil in forum Samsung Galaxy S4
    Last Post: 04-14-2015, 01:30 PM
  2. Notification LED issue and question how to change it?
    By speed13 in forum Samsung Galaxy S6
    Last Post: 04-13-2015, 11:47 AM
  3. Ok, so a few questions on customization
    By sandman512 in forum Samsung Galaxy S6 edge
    Last Post: 04-13-2015, 06:49 AM
  4. Audio question: 4K vs 1080p...Is there a difference
    By Matthew67899 in forum Samsung Galaxy S5
    Last Post: 04-13-2015, 01:58 AM
  5. Question on verizon update #1
    By droid747 in forum Samsung Galaxy Note 4
    Last Post: 04-13-2015, 12:18 AM
