Looking for a car dock for your shiny new Galaxy S III? Have the Motorola one for your Droid X? Then use it!
Step 1: Remove the spacer piece.
Step 2: Remove the screws from the back and tuck the microUSB connector into the base.
Step 3: Add something to give the base a little more height on the left side so the volume rocker is not being pressed. I used a piece of a gift card.
Step 4: Place your GS3 into your nice secure car dock!
Reading Android Central while driving is not recommended
It's a pretty tight fit so I don't think you'd be able to use it with a case.
