Looking for some information:
1. (Slightly off topic) What's with all of the [Note], [Tip], etc formatting? Does it all make sense when viewed in a browser? Any ideas if the Tapatalk app will be updated to incorporate this functionality?
Yes, you need a browser to read the HTML code properly. If you are using Tapatalk and want to see what I mean, load the thread in your browser and you should see the difference. It makes it look neater and cleaner.
2. Is there an approved method to flash the radios using ClockworkMod? That's how I used to do it on my HTC Thunderbolt and Incredible - any explanation as to why this phone is different? (Although not a big deal having to use a computer/ODIN, it's just extra 'stuff' involved, and any time there're extra steps involved yours truly will find some way to screw it up
Do you mean the app ClockworkMod? If so then no I would NEVER recommend that you do that. Too much can go wrong with flashing radios and using a program to do it just adds to what can go wrong. If you mean flashing in a manual recovery then yes you can. The original thread over on RootzWiki have recovery flashable zips.
3. I have yet to come across a good explanation of why I should unlock the bootloader if I'm just sticking with the stock (rooted) ROM - seems like one more step to potentially bugger up (see previous note about my ability to muck up something simple).
You don't need to unlock the bootloader to flash radios with ODIN. I don't know where this is coming from back unlocking the bootloader will give you the ability to flash more ROMs and kernels. The way the phone should have been if Verizon didn't tinker with it. You don't have to unlock it, its all personal preference. If you want to flash something like CM10 or AOKP then you will need to unlock the bootloader, but if you are perfectly content with staying on stock rooted you are fine. If you ever decide to flash a ROM, make sure to find out if it requires that you unlock the bootloader.
Unlocking the bootloader will not "bugger up" your phone unless you personally do something you weren't suppose to.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
