1. dpham00's Avatar
    Download the anycut apk,
    Select Activity > WiFi Debug Screen
    This will create a shortcut to the wifi debug menu.
    Under "WIFI Power Save Mode", toggle it "OFF".
    07-17-2012 03:05 PM
  2. strtgng's Avatar
    What exactly does the WIFI Power Save Mode do?
    07-17-2012 03:17 PM
  3. dpham00's Avatar
    It decreases wifi power consumption. Normally. If you don't have any problems, then I would leave it alone. But if you have weak wifi, then you may want to try to turn it off for better wifi performance.
    07-17-2012 03:22 PM
