I had this exact same issue.
You have 2 options;
1) Factory Restore your device
2) ROOT your device, install ROOT Explorer, navigate to / > data > clipboard, select ALL and delete all, than go into your Settings > Applications Manager > All, look for TestServices, than remove updates/clear data. Reboot and everything should be fine.
I opted for option 2 simply because restoring a device sucks and I wanted to root anyways because I missed AdFree, ROOT Explorer, and could not stand the WIFI Notification.
Essentially what happens is something in your clipboard becomes corrupted by TestServices. You basically have to clean up a mess you did not make.
Thanks appreciated
Sent from my SCH-I535 using Android Central Forums
