Well, I was ill today, so I stayed inside the hotel and managed to get data working. Here ya go:
1) ROOT THE PHONE
First, I rooted the phone (as well as gave it an unlocked bootloader), which I've never done before... I did it using this xda guide... and followed every step. I chose the ClockWork recovery mod.
It wasn't bad if you read over the steps, familiarize oneself with the video, and read through the steps again.
http://forum.xda-developers.com/showthread.php?t=2046439
Download Titanium Backup Pro via Google Play store
Download HiAPN Global via Google Play store
2) Use Titanium Backup Pro to turn HiAPN Global into a system app
-- you do this by going to the Backup/Restore tab, and LONG HOLD on "HiAPN Global", and then choose "Convert to system app"
3) Open up HiAPN Global, and choose "Click to AutoSet APNs"
-- here, you're possibly done!
Note:
-- HiAPN will ask you if you want to blow away the other APNs in the list... it recommends blowing away the old list... a couple of comments here.
I don't think it matters either way, 'cause I tried both ways... it, in my case figures out the information (I guess) from the Entel servers, and writes the APN entries into the list. If you choose the option to blow away the APN entries prior to writing the new ones, it will delete all of the Verizon settings. You can get the Verizon settings back by choosing the menu option (the only menu option in the APN Settings screen) called "Reset to default." I've tested this, and it brings back the Verizon settings. You can also, like I did, choose to backup the APN settings using HiAPN or other APN programs which will store a private backup of those settings just in case.
-- I've also tried using the APN settings found in "Offline SIM APN Database Pro", as well as "Tweakker" (which I was able to install via Aptoide, 'cause Google Play says it is incompatible), and then entered the APN settings in via APN Manager Pro (after having converted it to a System App)... well, all I can say is that I don't think this is necessary to manually enter the data if HiAPN works for you... it just magically finds the correct settings from the operator, and BTW, they weren't exactly the same (but very similar) as the others I had found using the other apps. Though, the other settings had worked, I suspect the most correct settings will be through HiAPN.
I'm currently able to use data in Santiago using Entel.
Thanks (not!) Verizon...[/QUOTE]
I originally tried with APN Manager Pro. My SIM wasn't working. After I switched to HiAPN, it worked!
Thanks for your post. You saved me much grief!
