Ok. I have myself completely confused.
I have TWRP installed. THOUGHT I was following directions, but apparently missed a step somewhere. (samsung drivers on PC)
I was attempting to install synergy. Did factory reset(wipe)
The state of the phone now is:
It boots up into TWRP.
When connected via USB to my computer, I do not see the phone as a device. (win8). I have Hemdall and Oden installed. If I have TWRP up, Hemdall sees the device as an option in the USB devices (samsung_android_SCH-I535). If I attempt to put it into download mode, Hemdall no longer sees the samsung device in the USB options.
I have read about a dozen different options for down loading the Synergy ROM (Synergy-S3_19Apr13_1622_r484_s) but I can't quite figure out what to do with my set of options. I can't put the phone into download mode, or Hemdall loses the phone in usb. Not sure if it is in TWRP if it can run Hemdall. Oden doesnt see anything at all when TWRP is up, sees 0:[com5] when in download mode.
So....which combo do I need to download my Synergy ROM?
Thanks. Im an *****.
