1. Nussbuss's Avatar
    I am currently using the Nova Launcher on my Galaxy S3, and have all of the current updates for the verizon network. I like the battery status icon that comes in the facory settings with the option for showing the percentage as well. However, there is another battery status icon on the left side of my pulldown menu with my notifications. I do not know how to remove it! I have tried all factory and Nova settings, as well as many forum searches to find the source for this icon. At this point, I do not know if it is from the Nova launcher, or something that has come from another application I have downloaded. Please help!! I will attach a screenshot. Look in the very top left corner of my screen for the blue numbers-that is the icon.
    Attached Thumbnails Verizon Galaxy S3 : Battery status icon won't go away!-2013-07-31-15.51.08.png
    07-31-2013 04:06 PM
  2. GSDer's Avatar
    That looks like an icon from a battery saver app (Juice; GSam; etc) - I haven't seen anything like that from Nova Launcher.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4 Beta
    07-31-2013 07:35 PM
  3. drmaf894c's Avatar
    If it is from Nova launcher it should be able to be turned off in the settings area. I don't use NOVA so I couldn't tell you for sure (primarily using Apex at this point). Typically there are going to be setting for "theme" or something that would allow you to alter the way the battery icons look so that may be it but as stated above it could be from a 3rd party battery monitoring app as well?
    08-02-2013 06:47 PM
  4. K1sso's Avatar
    I have the exact same icon in my status bar, and I have no idea where it came from. Not nova launcher, or any other launchers. I'm on the Nexus 7 (2013) with stock android, and I don't have any battery saver apps installed. I'm thoroughly perplexed as to where it came from. I've tried looking at all my installed apps and I've stopped various processes to see if it disappears, but to no avail. If anyone have any idea where this came from, please help.
    11-26-2013 06:33 PM
  5. GSDer's Avatar
    K1sso,
    It's definitely a 3rd party app.
    If the Nexus 7 has a 'Safe mode' (which excludes all 3rd party apps from running) you should try that. Otherwise you'll have to do it the hard way and start uninstalling apps that have 'power' or 'saver' or similar verbiage in the title.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    11-27-2013 12:26 AM
  6. rxgadget's Avatar
    Take a look in your apps for GSam Battery. Also take a screen shot and post it here for SG3 or on Nexus 7 2013 forum
    Sent from my SCH-I535 using Tapatalk
    11-28-2013 01:48 AM
  7. mdeva's Avatar
    Only ONE battery icon? Nice. I have two.
    12-06-2013 05:27 AM
  8. Peter Chrisbacher's Avatar
    It looks like the battery status icon from Notification Toggle by J4velin. You're welcome
    05-30-2014 08:07 AM
  1. Google Chromecast : Netflix battery life issue
    By nick_krawczyk in forum Google Chromecast
    Last Post: 08-07-2013, 03:50 PM
  2. Homescreen Icons Cleared to Default After Soft Reset
    By daaarn in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-06-2013, 12:25 PM
  3. Galaxy note 2 battery questions...
    By umer yes in forum Samsung Galaxy S4
    Last Post: 08-01-2013, 03:18 PM
  4. Galaxy note 2 battery questions...
    By umer yes in forum General Help and How To
    Last Post: 08-01-2013, 10:30 AM
  5. Galaxy note 2 battery questions...
    By umer yes in forum Samsung Galaxy Note 2
    Last Post: 07-31-2013, 04:38 PM
We have updated our Privacy Policy and Terms & Conditions. Please check them out.
