1. briguy-AC's Avatar
    I bought one of the USB OTG cables on Amazon that is advertised to work for the GS3. I connect it and nothing happens. My friend has a Sprint GS3 and he gets a notification about the USB being connected when I tried it on his phone. Is this an issue with Verizon phones? Any way to get this working? Thanks for the help.
    10-26-2013 12:46 PM
  2. Adamsberg's Avatar
    You'd try your friend's cable on your phone
    The message isn't showed for long, maybe you missed it ... aah ... and did you connect a thumb drive to the cable? Just the USB OTG cable without a USB device connected won't give you a notification.
    The thumb drive should be shown as USB storage on your file manager.
    10-26-2013 02:14 PM
  3. GSDer's Avatar
    Sorry to have to correct you, but the phone does (briefly) show a notification when the USB-on-the-go cable (by itself) is connected.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Adamsberg likes this.
    10-26-2013 03:02 PM
  4. GSDer's Avatar
    Sorry, looks like you got a POS - the original Samsung cable that I got works fine on my Verizon S3 (4.1.2, MF1) [although there's not enough juice to power a USB hard drive]
    10-26-2013 03:04 PM
  5. Adamsberg's Avatar
    Sorry to have to correct you, but the phone does (briefly) show a notification when the USB-on-the-go cable (by itself) is connected....
    Well ... my phone does not, but it isn't a Samsung.
    Thanks for the clarification that the S3 acts this way
    10-26-2013 04:57 PM
  6. Adamsberg's Avatar
    ... the original Samsung cable that I got works fine on my Verizon S3 (4.1.2, MF1) [although there's not enough juice to power a USB hard drive] ...
    One of these USB OTG Y-cables or a powered USB hub doesn't work with an USB HD ?
    GSDer likes this.
    10-27-2013 03:17 AM
  7. GSDer's Avatar
    One of these USB OTG Y-cables or a powered USB hub doesn't work with an USB HD?
    It very well may - I was just pointing out that it doesn't work by itself.
    Thanks for the suggestions.
    10-27-2013 12:25 PM
  1. PS3 bluetooth controller working on HTC one?
    By ohlad in forum HTC One M7
    Last Post: 01-14-2016, 12:51 AM
  2. Verizon Galaxy Note 2 - Netflix does not look good
    By robinhelenehebert in forum Verizon Galaxy Note 2
    Last Post: 06-08-2014, 01:17 PM
  3. Galaxy gear question
    By Ronnie Jordan in forum Samsung Galaxy Note 3
    Last Post: 11-07-2013, 03:57 PM
  4. Opening case not turning on
    By sbudaj in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-28-2013, 10:16 PM
