1. Jace's Avatar
    Tragically, my rooted phone recently started crashing for no reason, then decided to stop turning on altogether after I tried a Dummy File Generator fix described in xda. Now there's no download mode or anything, so I can't fix it or remove root.
    Anyone return rooted phones (bricked or non) to Verizon before? Do they care?
    Opinions/solutions much appreciated!
    -J
    10-29-2013 04:58 PM
  2. anon(749368)'s Avatar
    Are you sure it won't turn on or is it just out of juice? Battery pull didn't solve anything? Plug it into your computer and see if it gets recognized. If all fails, call Vz and ask for warranty replacement without telling them you rooted. They'll issue a replacement and you just send the phone to them when you receive the replacement. I did the same with my rooted phone (it was still working) and never heard anything from Vz. They reflash the OS when receiving returns anyway....
    Jace likes this.
    10-31-2013 01:04 PM
  3. GSDer's Avatar
    Jace,
    You should purchase a JIG (from Amazon or wherever) as a last-ditch effort to get the phone to boot into Download mode. Even if it doesn't work, they're still handy to have around when you mess with rooting.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Jace likes this.
    10-31-2013 04:43 PM
  4. nyry's Avatar
    100% agree with this. Just claim ignorance to what happened to your phone and they won't give you issues.
    11-01-2013 06:29 PM
  1. Can I Get My AT&T S4 to Work on AT&T Straight Talk Network
    By LegendsCreekFarm in forum AT&T Samsung Galaxy S4
    Last Post: 05-09-2015, 11:00 PM
  2. Galaxy S4 - Gallery Freezing and Force Closing
    By Wildo6882 in forum Samsung Galaxy S4
    Last Post: 01-14-2014, 07:10 PM
  3. thall, a game literally breaks your phone screen
    By ak_ashcool in forum Developer Spotlight
    Last Post: 01-01-2014, 09:02 PM
  4. Galaxy Note 3 - Did anyone notice!!!
    By karan1389 in forum Samsung Galaxy Note 3
    Last Post: 10-30-2013, 06:52 PM
  5. Problem uninstalling galaxy gear manager
    By JF7FSU in forum Samsung Galaxy Note 3
    Last Post: 10-30-2013, 07:15 AM
