problem with calendar notification settings
Hi,
I do NOT want automatic notifications on every event I add to my calendar. I keep going to the Calendar>settings>general settings>Notifications & reminders and UNchecking the Notifications box and then changing my default reminder time to "none". This works for a little while (days? weeks? not many) and suddenly I notice that, once again, I have default reminders 15 minutes before every event. What am I missing? I am using the default Samsung calendar app but I have it set to only display my google calendar.
I read in another post a suggestion to check the settings in Google from the PC, but I can't find anything there that pertains to my phone calendar notifications.
Re: problem with calendar notification settings
Try Calendar: http://market.android.com/details?id...droid.calendar instead?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
Yes, that's the calendar app I'm using. Sorry, I didn't make that clear. I think I got it, though... I just discovered that if you go to Settings>app manager>calendar, there is a check box that says "Show notifications". I unchecked that, and I hope there are no more hidden check boxes for notifications. Why put the setting in the calendar itself if it gets overridden somewhere else?
