1. RAT32's Avatar
    This just started last night. I plug in my charger and see a red flashing light and I get a message that tells me it can't charge and to make sure I am using Samsung compatible battery and charger. Been using the same batteries and charger for quite some time.
    Any help would be greatly appreciated.
    09-20-2014 03:45 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery might be failing--try a new one. Or try a different charging cable/plug.
    09-20-2014 04:24 PM
  3. gozirra's Avatar
    Your experience may vary, but mine started doing this a few weeks ago. It is much less severe on WiFi. It was so bad last night, I had it plugged in to a stock charger (that came with the phone) for six hours, and I LOST 20% more charge. Got home, got on WiFi, plugged it in, and an hour later it was back to full charge.
    09-21-2014 10:56 AM
  4. blunt_eastwood's Avatar
    Is it a flashing red light or a red x over the battery icon?
    09-22-2014 04:45 PM
  1. Will not turn off or charge with magnetic cable
    By maxburn in forum Sony Xperia Z2
    Last Post: 10-11-2014, 08:28 AM
  2. Will the Note 4 have the same issues plaguing the LG G3?
    By anon8126715 in forum Samsung Galaxy Note 4
    Last Post: 09-20-2014, 05:28 PM
  3. phone not charging
    Last Post: 09-20-2014, 03:59 PM
  4. Replies: 0
    Last Post: 09-20-2014, 01:40 PM
  5. firmware upgrade enocountered an issue
    Last Post: 09-20-2014, 05:48 AM
