Since last 2 weeks I have been experiencing the problem. Galaxy S3 on kitkat is not taking charge at all. When I connect to the charger, it charges for a few second, then automatically disconnects and then again connects showing a red x on the battery. The charge keeps on getting less instead of increasing. Again I pull out and push the charger, it again charges for few seconds and the disconnects and then connects showing a red x. I tried removing the battery and re-inserting it, switching of the mobile phone while charging, nothing helped out.*i tried changing the battery it didnt work. I used multiple cables and sockets, it didnt work either.
I am sure there's absolutely no problem in the charger because I have one Galaxy s4 and another s3 at my home, they get charged in the same charger perfectly. I tried charging my S3 through their chargers, I got the same result.*
I tried to charge it through my laptop's USB port, its the same. Nothing is working out. It also frequently switches on the screen, opens the S-Voice and closes it immediately, opens the desk organiser and closes immediately, and it keeps on happening non-stop.*
Any solution?
Any solution?
