experiment 626
Re: 5 hours???
This is the way to go.The Extended Battery really allows you to enjoy this phone unencumbered through the day.And since the extended battery door is beveled with it's bottom slightly concave it doesn't look near as blocky as some other extended battery set-ups.
I bit the bullet and picked-up the extended battery. The phone is bigger, a bit heavier; although, it's much more comfortable in-hand than my DInc was with the Seidio 3500 mAh.
HTCPedia still has it priced at $33 HERE.
So far now, my Rezound lasts all day with heavy-ish use. With moderate to light use, I could go a day and a half easily.
