Definitive Rezound Battery Life Saving Method
phorts
9
Here's how to save your battery life.
- Turn off WiFi, BlueTooth and GPS
- Turn off 4G LTE
- Turn off all Location Services
- Turn off all Sync Services
- Turn screen brightness to lowest setting
- Turn screen timeout to lowest setting
- Place phone in Airplane Mode
- Dont make phone calls
- Dont text, email, surf the web, play games or use any apps
- Place phone in box
- Send back to Verizon
Sorry. I love EVERYTHING about this phone, except the battery life. I bought it so that i could DO all of the things above and more. I have to limit my usage and disable key functions of the phone just for the HOPE that i make it through the day. This is my 4th HTC Phone (Eris, DInc 1 and 2) so i'm well aware of how to manage power consumption. But even with my advanced knowledge, I'm still coming up short every day.
Not much that complaining will do about it, so i'm going to do what everyone else is going to do...live with it, because i like the phone that much.
Ext battery is not an option for me as already the phone is a beast. Dont think i'll be making it two years with this one....hopefully they come out with a slim ext battery (that's bigger than the 1950mAh Mugen one...what is that? 15% more? gee..thx).
Im holding out hope that ICS will improve the battery as much as Gingerbread did w/ the Dinc 2.
Thanks for listening to this Rant :)
ajnevares
180
5
Hey, it worked! lol
I hear ya on the battery life, I love this phone and very aware of the processor and screen being primarily responsible for consuming the battery and those same things are what makes the phone great, but I have realized I use my phone for 4 things...phones calls, texting, facebook and music...do not need an Android, nor 4G for that. I just wish I would have realized that before my 14 days were up :-\
jimbl
1,010
37
I didn't think I'd like the extended battery either, but come to find out it doesn't bother me at all. I might even prefer the added bulk. I know, I'm crazy.
SurfingJerry
207
8
I now always carry a spare micro USB cord. It's lightweight, takes little room and USB is so ubiquitous it's easy to get a power boost.
I also have a USB wall plug (palm brand with folding blades) and a CLA USB adapter for car use (in case I'm not in my own car).
Having these three items which all together easily fit in one hand was cheap and keeps me powered.
The only other thing to have is a portable external battery pack, but I only take that when I know power will be scarce (sporting event, hiking, etc).
It's not htc or android's fault that battery tech is lagging. All you can do is deal with it. I find that addressing the recharging capability is the most reliable method rather than trying to squeeze blood out of a stone.
evetskirk
13
That pretty much is the answer? Lol Seriously though, I like slimmer phones too and was reluctant to get the extended battery (2750) because it added to the bulk of the phone. Glad I did, makes a huge difference. Also its really not that bad as far as adding to its size. The extended case is designed well. I will however go back to stock back when there is an extended battery with enough juice to fit it.
Sent from my HTC Rezound using tapatalk
xxfallacyxx
Bearded
Aug 18, 2011
739
56
ICS sees much better power management from what I've experienced.
That was on Scrosler's Senseless ICS ROM, wifi & data on screen @50%, OEM battery.
On the stock OS I saw roughly 13 hours from a full charge.
buckifvr
872
18
- Turn off 4G LTE
I have a much simpler solution to improve battery life on the Rezound. JUST TURN THE DARN THING OFF!!!
MrSmith317
Mr Fix-It
Mar 1, 2010
2,206
277
No matter what you do short of what the OP suggested you can't get the SLCD to suck up any less power. Even turning the brightness down doesn't do much(if any) good. I've already resigned myself to leaving an adapter at work, in the car, several at home, and one that is in my travel bag. So unless there isn't electricity or a car battery I can stay powered on.
WebmastuhB
11
Yep, do those things. USB chargers and cables can be bought on eBay CHEAP. Buy 10 of each, leave them all over the house/work/car, etc.
The extended battery is fine. I also like the weight better, of course, I use a Bluetooth headset all the time.
I may look into a battery pack charger just in case.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Make sure that it is a quality charger,or else it may damage the phone.
ShaggyKids
2,714
37
48
I gave up ln my TBolt after just one year because of the lousy battery life. I could no longer deal with the extended battery bulk and weight.
Got me a Rezound and for the first week it was battery life heaven :) Now its battery life HELL. My phone just about lives on its charger. I pretty much leave it plugged in constantly at home and that's no exaggeration. Put it in my pocket to take a half hour walk the dog break and I have just over half a charge when I get back.
Way worse than my TBolt. Waiting for my replacement battery which was SUPPOSED to be here today and didn't arrive.
Sent from my Rezound via TapaTalk
rootbrain
742
70
If you're crazy we're both on the way to the looney bin. I have ext battery with case and belt clip from VZ. And I'm liking it.
Those that thought the Rezound was too "thick" before will hate it, but when I held the ReZound and RaZr the Rezound felt better to begin with. And it wasn't "thick" it was just "thicker" than the RaZr.
Plus my case from VZ has the kickstand and it's great. And it add protection to the camera lens and screen by buffering them a bit from when I lay it down.
phorts
9
So that's been my problem too, finding quality chargers. For my DInc1 and 2 i bought a bunch off monoprice.com for a few bucks ea. But, i always found that they were inferior to the Verizon charger, using the 3rd party ones for bump charging only and the verizon one for my night charge. Now, my car charger doesnt even work at all with the Rezound. This too was 3rd party, cuz i'm a cheap ass.
But, i dont want to go drop $20/ea for Verizon brand chargers. What are the best options out there that are both quality and inexpensive?
I also looked into the Car Dock for the car. There's a 150 post thread on another forum about it and i didnt have the time to read through it all, but a lot of folks are angry that their existing car charge cables dont work or dont work very well with it. What's the proper charger for the car?
Thanks for the help!
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
I bought Palm 5v/1a wall and car chargers for under $4 a piece. The wall chargers were from Verizon, car chargers from att. This was some time ago though, so may be sold out. I also bought a Belkin 5v/3a dual car charger (1a on one port/2a on the other port for $5ar a month or two ago, but that deal probably expired already. best thing to do is to set up deal alerts on your favorite deals website, i was able to find plenty of stuff that i needed for cheap this way.
tiberius72
Active member
Jul 18, 2011
39
I second that. I once got one of those mini to micro usb converters so I could use an old Moto car charger.
That converter destroyed my Blackberry's micro usb port. I could not charge or sync with a PC ever again - all because I got a crap $1 converter from Meritline. They acknowledged that batch of converters was bad and all they did was give me a $5 credit.
I had to live with that device for another yr.:(
Please always get a good charger folks.
tiberius72
Active member
Jul 18, 2011
39
I got some HTC OEM stuff from all4celluar the other week. I was actually expecting the ext-USB cable as I check the part numbers, but they sent some HTC OEM mirco usb cable. Not really disappointed as the stuff is all HTC OEM and excellent quality,
Here is the link.
HTC micro-USB Power Charger - $4.95
I should of order this - the extusb data cable
HTC Mini ExtUSB Data Cable (EMU) - $2.49
I order some of these as well
HTC USB Car Chargers - As Low As $2.45
I ordered monocable microusb charger for 1 dollar. It works but seems cheaply made..
chasenfreedom
46
I completely understand I like it 2, it let's u knw ur phone is still on u but I dnt like when I'm laying in my back and holding it then tha weight becomes bothersome
steve1084
