Battery and screen problems
milo_green
I got my htc rezound from a friend because he upgraded to the DNA
And when I first started using it, it only lasted a hour of use and an hour and a half without using it
I searched YouTube for help and I started deleting or force stoping apps and now
when I turn it on I have to scroll the notification center down tap on an app , then a pop up says unables to proceed Because com.htc.dg
And the battery lasts 2 hours now of mild use and I need help bad
pretext
326
18
I would do a factory reset and go from there. That way you'll have a clean slate and can determine if you possibly have a bad battery or not.
Sent from my Nexus 7 using Tapatalk HD
mike7728
253
11
I agree with T-REX,then if u find out its the battery,I recommend buying the extended.
SENT FROM MY S-OFF HTC REZOUND RUNNING VIPERREZ
Jude526
Trusted Member
Dec 13, 2010
3,936
109
Whenever there is a big issue factory reset is the first step
sent from either my HTC Rezound or my Samsung Galaxy 10.1 tablet
acejavelin
1,935
27
I agree as well, factory reset then install GSam Battery Monitor, so you can see where the battery is going. If that doesn't seem to make things better, consider a new battery. Note that the Rezound is not really known for battery life, about 2-2.5 hours of screen on time is typical of standard battery.
samyblaze
