Re: Battery Won't Charge Fully
Hi Friends I Have A Best Solution For Battery Charging Problem.
There Is No Hardware Problem, No Battery Problem & Not A Charger Problem It's Only Software Problem So Just Do This Trick Below
(No Need To Flash Your Device It's A Simple Trick To Do)
(1) Discharge Battery Fully & Let Device Power Off It Self (Do Not Plug Charger)
(2) Wait 5 Minutes (Do Not Plug Charger)
(3) Press Volume Down + Power Key To Start Device (For Samsung Users Press Only Power Key)
(4) Again Let Your Device Battery Dry Down & Device Will Automatically Power Off
(5) Now Press Again Volume Down + Power Key (Samsung Users Press Only Power Key) If Your Device Start Then Let It Again Battery Dry Down.
(6) If Your Device Only Vibrates & It Don't Start Then Press Only Power Key After Few Seconds.
(7) Plugin Charger (Don't Power On) Leave It For 3 To 4 Hours To Charge Battery Fully
(8) If You See Again Battery Charges Between 50% To 78% Or 79% Don't Worry Just Plug Out Charger And Press Only Power Key & If It 100% Charged So Plug Out Charger & Press Only Power Key. Now Again Plugin Charger For 30minutes.
(8) Now You Can Use Device And Dry Down Battery Upto 50% & Now Charge Device And It Will Charges 100%.
NOTICE:- (1) IF YOU WANT TO RESTART DEVICE PLEASE DON'T USE "REBOOT" OR "RESTART" OPTION BY PRESSING POWER KEY JUST USE "POWER OFF" OPTION AND AFTERWORDS PERSS ONLY POWER KEY TO START DEVICE.
NOTICE:- (2) DON'T DRY BATTERY LESS THAN 40% TO 35% CHARGE THE BATTERY REGULARLY.
