U Upstreammiami Well-known member Apr 18, 2010 2,098 482 0 Visit site Dec 12, 2011 #2 GlenSilvestre said: Anything I can do for this? Click to expand... yes call verizon lol
D drholyoak Member Aug 15, 2011 7 0 0 Visit site Dec 12, 2011 #3 Mine is like this as well; doesn't always work until I push it a few times... I haven't found a solution.
F finchdroid Member Jun 5, 2011 21 3 0 Visit site Dec 13, 2011 #4 GlenSilvestre said: Anything I can do for this? Click to expand... You can try this if you like How to Mod your Power Button, Thunderbolt
G GlenSilvestre Member Dec 5, 2011 9 0 0 Visit site Dec 13, 2011 #5 cant call verizon, someone else gave it to me so im pretty sure i dont have warrenty. and thanks will check the mod
J jd07bos Well-known member Jun 23, 2011 218 12 0 Visit site Dec 13, 2011 #6 ROOT!!!!! then you can use your volume keys to wake the phone up......
J Jude526 Trusted Member Dec 13, 2010 3,936 109 0 Visit site Dec 13, 2011 #7 In Arizona malls there is a company called GOTRONICS and they have kisoks set up in the malls. They repair electronics and if they are in your area, you may want to look into it.
