Hey.. was wondering if anyone knows any free apps that i can download on my Htc Thunderbolt and just use my mobile network not have to pay for the mobile hot spot... Any suggestions? And i can not hook up with Bluetooth to my Windows 7 Laptop
If you have Wifi support on your local network just turn on the TBolt's Wifi and you're on. If not, you can add Wifi to your local network for a one-time access point cost. You don't need any special aps for this.
-Frank
Sent from my HTC ThunderBolt 4G/LTE using Tapatalk
If you are rooted there are several options. If you are not rooted then the only options you have would require a cable. like clockworkmod tether.
I'm unrooted..
For the record this is a 14 day trial which then caps you at 20mb unless you purchase it for $5 or so...yeah, if non-rooted, you'll need to download "ClockworkMod Tether (no root)" from the play store.
link: https://forums.androidcentral.com/e...S5rb3VzaGlrZHV0dGEudGV0aGVyIl0&token=UJeI7VfH.
then you'll use a usb cable.
