My ringtones and notification tones keep changing....(help)
Rain816
Active member
Mar 17, 2011
27
Ok...i use hancent sms but i have a dave chapelle notification tone set....every morning i wake up and my settings have changed on thier own...how do i stop this....its getting annoying to redo evrrything everyday....plz help thanks
tallen316
Active member
Feb 9, 2011
36
Well I am glad to see that someone else is having the same issue as I. I kept thinking that I was crazy but my phone would change tones and notifications as well. For the last couple of days I havent had any issues. I moved my tones and notifications to where you are able to choose them from the setting options. I am not sure if this is what has fixed my problem or not....
saraheba
66
I know mine would get changed if they stayed in download folder. Fixed when I moved and renamed.
Sent from my ADR6400L using Tapatalk
GoldLeader
198
17
Ok...so how do i move them...ive never done that before
Cyber Warrior answered this in another thread. You just need to add specific named folders to the root directory of the SD card while the phone is connected to a computer via USB.
http://forum.androidcentral.com/htc-thunderbolt/70415-music-folder-question.html#post750327
Set up folders on your SD card like this:
Music
Ringtones
Notifications
Alarms
Movies
Videos
Pictures
..and place the files in their correct folders.
fallingOutOfLoveWfithTech
