Anyone have a problem with their ringer volume? I can barely hare the ringtone when someone calls me, unless i'm sitting right next to it? Is there any apps to increase the built in volume?
Are you using a native HTC supplied ringtone? Which one?Anyone have a problem with their ringer volume? I can barely hare the ringtone when someone calls me, unless i'm sitting right next to it? Is there any apps to increase the built in volume?
Well, that does seem to narrow the problem down to the specific ringtone you made. Can you edit it and increase the volume?I use my own ringtones that I make, Everything else is fine with the speaker as far as my sms ring tone, and when I play music it's loud and clear, but just when I receive a call that my ring tone is barely being heard unless i'm sitting right next to it. I don't know what's wrong, I have my volume set to the highest???
Well, isn't the speaker about 90% blocked by the kickstand when it's closed?
Good Morning,Anyone have a problem with their ringer volume? I can barely hare the ringtone when someone calls me, unless i'm sitting right next to it? Is there any apps to increase the built in volume?
Hi Cynical,I have a problem with my volume as well. It is not (in my case) a ringtone problem. Selection sounds are almost inaudible, screen lock sound almost inaudible, stock ringtones I can hear only when sitting next to the phone (which are not loud which I might add) and my ringtones I've made are the same as stock (yes I have increased the volume on them). I experimented with the kickstand closed and opened. I hear no difference. Also when putting the phone to vibrate, then back to full volume all sound is cut in half from their current reduced rate until the phone is reset. It really seems it's either software or hardware related.
It has to be the program you are using to make your ringtones or the files themselves because I only have one really soft ringtone and it was soft on the other phones I had it on also. I was just testing all of them out and my animals were going crazy and my wife said it was loud.
Sent from my Thunderbolt
Good Morning,
I had the same problem I could turn my ringer all the way up and I still could barely hear it, I thought it was the specific ringtones in which I used so I tried them all still no help, when I started hearing people complain about my speaker echoing I got fed up and exchanged my phone. It was the speakers, now my phone can be on low and it's still loud and no more echo and hissing sounds. Hope this helps
