1. ktrent's Avatar
    I am having issues with some numbers not showing up on the dialer screen. They do however show up in call history. It is not one particular contact and it happens randomly. I never had this issue with incredible. I have restarted with no help. Is there a setting to fix this. It's not a issue I can't live with but I just hate little bugs like this. BTW I am still on stock out of the box version. I have not updated.
    Sent from my ADR6400L using Tapatalk
    06-03-2011 11:24 AM
  2. saraheba's Avatar
    Is this what is happening: you press the phone dial button, start typing a name and nothing shows up? If so, mine does that and I usually type one letter then delete it and my call history will show up like it should.
    06-03-2011 12:12 PM
  3. ktrent's Avatar
    No that is working fine. It's not listing some of the calls on the list at the dialer. Like if I call someone sometime it moves there name to the top and sometimes it doesn't. It also is not showing missed calls in the dialer. All call are in history perfect. It is just not moving calls to the top in dialer list.
    06-03-2011 01:36 PM
