1. Bloodthirsty's Avatar
    Wondering if I'm the only one.
    If I leave my phone on the charger for say 30 min to an hour after it says 100% charged it holds that 100% for a while....say a couple hours.
    If I take it off right after it says 100% the percentage falls down to 99 rather quickly.
    11-05-2013 11:50 AM
  2. Golfdriver97's Avatar
    The percentage I believe is based on average use over a set period of time. If true, that would explain why it discharges quickly one time and longer the next.
    11-05-2013 11:52 AM
  3. Bloodthirsty's Avatar
    No I know that. What I'm saying is that if I leave it on the charger and with almost identical usage it holds the 100% charge longer if it's kept on the charger for a while after it says it's fully charged.
    So say if I leave it on for a while it's almost like 105% or 110%. Think of it as squeezing some extra gas in your gas tank after the pump kicks it off.
    11-05-2013 11:58 AM
  4. Rcrdude64's Avatar
    It's not necessarily extra gas, it's how the system displays 100%. The green light comes on early 99% of the time to prevent overcharging if I remember correctly. It's also a possibility the battery hasn't had enough cycles to have a solid point of 100%. Same reason they tell you to leave an extended battery on the charge for extra time after the green appears.
    Sent from Xperia Note
    11-05-2013 12:10 PM
  5. Adamsberg's Avatar
    ... What I'm saying is that if I leave it on the charger and with almost identical usage it holds the 100% charge longer if it's kept on the charger for a while after it says it's fully charged.
    It would not be impossible ... the phone's charging control has the Li-Ion cells' max charging voltage of 4.2V just to increase to 4.3V for charging to 110%.
    But LG would embark on dangerous territory ... see Table 4 & 5 of Battery University's article ....
    http://batteryuniversity.com/learn/a...ased_batteries
    Therefore I don't think that this could be the cause for your finding.
    But to be sure you could install a battery monitor app like Battery Monitor Widget, the app would log the battery's voltage, even as a graph by time.
    11-05-2013 01:17 PM
  1. Galaxy S4: Is it safe to charge using a different charger?
    By Jude Mathis in forum Samsung Galaxy S4 Accessories
    Last Post: 03-28-2017, 08:38 PM
  2. Replies: 10
    Last Post: 11-06-2013, 05:42 PM
  3. Battery
    By Marihoene in forum Samsung Galaxy S4
    Last Post: 11-05-2013, 10:25 PM
  4. Setting the "Time" on a widget after clock change
    By Don Runowski in forum Samsung Galaxy S4
    Last Post: 11-05-2013, 01:49 PM
  5. Replies: 4
    Last Post: 11-05-2013, 11:24 AM
