1. Shotsie74's Avatar
    OK - I have looked through some of the forums, but haven't quite found what I need and I hope someone out there can help.
    I am trying to connect a Bluetooth Wireless Keyboard to my LG Revolution, but running into issues:
    - it will pair it, but not connect to it.
    - when I try to manually connect to it...it will not
    I have tried different options (and various wireless keyboards) and none of them are connecting.
    I am not sure what I am doing wrong because two weeks ago - it worked and now it does not.
    02-15-2012 03:39 PM
  2. Paul627g's Avatar
    Welcome to Android Central.
    I will move your post over to the Revolution's forums so you can get better support.
    Enjoy the forums.
    02-15-2012 05:02 PM
