1. ninelives1972's Avatar
    It seems pretty limited with what came with the phone. One car tag and one office tag. The customization that can be done with those two tags seem very limited. Am I missing something???
    It seems like a great concept, just not implemented very well.
    Would I have to buy LG specific NFC tags to use with this phone?
    03-23-2013 09:47 AM
  2. Patrick Schroedl's Avatar
    You don't have to buy any sort of proprietary NFC tags. However, some tags are rewritable and some are not, and some tags have larger storage capabilities and can therefore store more NDEF (NFC Data Exchange Format) data than others.
    Tagstand offers some nice tags which have all worked for me.
    ninelives1972 likes this.
    03-23-2013 01:30 PM
  3. alicechong7789's Avatar
    You can also try buynfctags.com. They have a variety of nfc tags and key chains, you can buy as little as 1 piece for some of the sample products.
    04-02-2013 01:40 PM
  4. balou88's Avatar
    Hello Nine lives!
    You can do quite a lot of things, check out some nice use cases right here. NFC Use Cases
    But you're right for now it's stilla great concept but not perfectly implemented
    For the NFC tag with a LG phone, you can basically used every NFC forum compliant type tag. Check them on NFC Tags from IdentiveNFC.com. They do have pretty cool design and high quality!
    04-22-2013 04:47 AM
  5. ninelives1972's Avatar
    Thanks for the info, I think the LG NFC app is junk. I downloaded NFC Task Launcher from Tagstand:
    It works consistently.
    They also gave me two free tags.
    04-25-2013 04:27 AM
  6. balou88's Avatar
    NFC Task Launcher is not perfect but it's definitely by far the best android app for NFC encoding.
    There is still a lot of possibilities missing though, but it works perfectly anyhow.
    How did you get those free tags? just by downloading Task Launcher? or did you apply for there cloud based platform?
    04-26-2013 06:36 AM
  7. AlgarY's Avatar
    I'm using NFC Task Launcher as well. But I also have NXP TagWriter just in case. Both are working great for me.
    04-28-2013 08:24 AM
  1. NFC/tags - using RFID
    By therealbill in forum Sprint Nexus S 4G
    Last Post: 10-24-2011, 04:16 PM
  2. You thought we were to flat?
    By drethos in forum General News & Discussion
    Last Post: 08-01-2011, 10:27 AM
  3. Why Wait For NFC Tags-Make your Own
    By Wiley_11 in forum Sprint Nexus S 4G
    Last Post: 05-24-2011, 09:42 PM
  4. Samsung thought they wanted my opinion
    By dragonpup in forum AT&T Captivate
    Last Post: 01-28-2011, 09:23 PM
  5. Replies: 4
    Last Post: 08-17-2010, 10:15 PM
